HPOP still no start.
Old Dec 1, 2013 | 11:11 AM
Dukhunt22's Avatar
Dukhunt22
I've read a lot of post on here about Hpop no starts, but still can't find problem. How do you check rails to make sure they are getting oil?
Chad
Old Dec 1, 2013 | 11:26 AM
mueckster's Avatar
mueckster
You can remove one of the oil rail plugs in each head and see if it is full. When the HPOP and reservoir are full, it fills the rails and oil will continue to seep from the rail port due to gravity. This also help purge any air in the rails. Reinstall the plug and leave it cracked slightly loose (o-ring barely touching) and crank over. You should see oil coming out around the plug.
Old Dec 1, 2013 | 03:25 PM
Dukhunt22's Avatar
Dukhunt22
I had oil coming from plugs when removed. I put back in and left loose. Turned the truck over and never seen any leaking from plugs. They were really loose. So what should I look for now, getting frustrated need truck to be running by Wednesday.
Chad
Old Dec 1, 2013 | 06:07 PM
Tugly's Avatar
Tugly
  1. Check IPR tin nut to make sure it is "snug", but not over tightened.
  2. Remove IPR to verify the plunger is free to "rattle".
  3. You can remove the Exhaust Back Pressure sensor (use two wrenches, it will bend) and mounting plate/bracket to verify the torque on the HPOP drive.
These are the things you can try before abandoning hope on the HPOP.
Old Dec 2, 2013 | 11:44 AM
Dukhunt22's Avatar
Dukhunt22
Are you talking about the torque on the Bolt with the big washer? We torqued it 25 lbs I know. I'm gonna take IPR out this afternoon and clean real good. I'll try the exhaust back pressure sensor idea if the IPR cleaning doesn't work.
Thanks for the ideas.
Chad
Old Dec 2, 2013 | 12:06 PM
m-chan68's Avatar
m-chan68
Chad
WHISKEY TANGO FOXTROT........
Ummmmmm....... the last time I checked (which is MANY moons ago, since I haven't seen any 7.3L trucks lately due to their age), the torque spec for that bolt is 95 ft-lbs. which is about the same tightness you would go for wheel nuts on a passenger car.
Old Dec 2, 2013 | 02:30 PM
Dukhunt22's Avatar
Dukhunt22
I may of looked at it wrong but I thought it was 95 Inch/lbs. it's easy to get too so ill go back in and torque it more if it needs it.
Chad
Old Dec 2, 2013 | 06:10 PM
mueckster's Avatar
mueckster
Chad
If you tightened the HPOP gear bolt to only 25 ft-lbs, the gear is slipping on the pump. Tighten it to 95 ft-lbs or at least until the motor turns and binds up under compression. Do this and your starting problem should be remedied.
Old Dec 2, 2013 | 06:39 PM
Dukhunt22's Avatar
Dukhunt22
Nope, I put 95lbs on it and broke the IPR valve down and cleaned. Put it back on and nothing. We can't get it to even smoke or sound like it won't a to hit. I got oil in the rails but don't know if I'm getting enough pressure to them. I don't have the gauges yet to test them. I don't know what to do now.
The first time I took pump out the Check ball fell out on other side of the rod of the non servicable plug. Will this damage the pump? I took it back out and put ball back where it supposed to be, but still won't crank.
Old Dec 2, 2013 | 07:26 PM
m-chan68's Avatar
m-chan68
The paragraph quoted above is likely the exact reason why it won't fire (due to not building up enough ICP psi).
aaron8669
25
Apr 17, 2021 11:43 PM
Jerry Chaney
Jan 11, 2014 08:10 PM
samsdad02
Modular V10 (6.8l)
May 17, 2012 05:20 AM
Powermonger
Sep 22, 2011 09:00 AM
andt350
Jun 6, 2007 08:00 PM
