Glow plugs, and injector o-rings
Hi I have a 2003 7.3L and I am about to reseal my injectors because there is oil going into my fuel system. also while I am in there that deep I will be doing glow plugs. my question is will a regular Chiltons repair manual be able to walk me through all of the steps? and if not where could I find the info?
I don't believe Chiltons will have what you are looking for. You can follow this write-up for injector removal and re-installation that Kwikordead did a few years back. You would just have to switch your old o-rings with the new ones, and then re-instal your injectors. Click here
There is another current thread right now discussing injector re-installation with some pointers. Click here
Here ya go, this might help you out. I always use RiffRaff and/or DieselORings write ups when applicable, I'm conjunction with FTE write ups of course.
http://www.riffraffdiesel.com/mm5/RE...structions.pdf
The glow plugs are pretty straight forward, but here's a thread I always recommend people read over. Some good pictures and torque specs for everything on page 2. You should retorque while you're in there.
Motorcraft glow plugs only!
https://www.ford-trucks.com/forums/1...w-plugs-2.html
bama29fan
11-01-2010 02:14 PM
chris64
19
05-21-2010 10:42 AM
Pele
07-17-2008 11:35 AM
