Minnesota Chapter Join Chapter, Leader: fordpower88
December BS thread
Old Dec 14, 2013 | 12:35 PM
  #586
Devious Delight's Avatar
Devious Delight
Originally Posted by HP junkie
What am I thinking.....if we are going to spend your money Dustin, here ya go!
*NEW* 2014 Ski-Doo FreeRide 137"
yuck. That's hideous. Who would buy that?
Old Dec 14, 2013 | 12:39 PM
  #587
Devious Delight
Here ya go Lee. You need a family truckster.
2000 Ford Excursion XLT
If I had a camper, that'd work... except it needs to be leather...
this one is perfect (and overpriced)
http://minneapolis.craigslist.org/an...222864437.html
Old Dec 14, 2013 | 12:40 PM
  #588
Devious Delight
Morning guys!
Old Dec 14, 2013 | 07:12 PM
  #589
MisterCMK's Avatar
MisterCMK
Hello everybody. I helped a buddy with his STI today. Loaded up the snowmoturd on the trailer with a fancy new cover. Whose great idea was this anyway?
Old Dec 14, 2013 | 07:45 PM
  #590
DieselCamper01's Avatar
DieselCamper01
Got the garage rearranged, the cycles away, and the snowblower & snowmobile in the garage. And got both running though the snowmobile isn't idling well.
Old Dec 14, 2013 | 08:45 PM
  #591
wildstang's Avatar
wildstang
VT Chapter Ldr
I had fun outdoors in the cold and snow.
Got the replacement plow on the explorer. Wasn't bad, had to move two tabs on each side and weld them back on. Still need to transfer the back drag from the old one to the other one
Showing the different mounting ear widths.
Showing where it bolts on and cross member modified. I left the outer most tabs in place, moved the middle ones to the far outside and moved the inner ones 1.5" father out. The original plow setup was for a small pickup so mounting tabs were 19" apart. The replacement is for a full truch and mounting tabs 22 1/4" apart. Going from 7' to a 7.5' plow now. Little heavier
Showing it modified and plow mounted in
Plow on explorer, 7.5' full size plow, heavier
When I first hooked up hoses, the angle wasn't working, pump would come on for left angle but not move, pump wouldn't come on for right. It was working with the old plow. Thought maybe ice in the pistons seizing them up and maybe cable out of adjustment. So I pulled the cover off the lower compartment, in picture. So got the cover off and it was half filled with ice not letting the arm move. Cleaned out the ice and now works good.
Old Dec 14, 2013 | 10:07 PM
  #592
DieselCamper01
That was a good day of work Jim.
Old Dec 14, 2013 | 10:11 PM
  #593
wildstang's Avatar
wildstang
VT Chapter Ldr
Didn't seem like it would take that long but it always does with fabrication work.
Sounds like you were productive also Jay
Old Dec 14, 2013 | 10:32 PM
  #594
MisterCMK's Avatar
MisterCMK
At least it runs Jay
These are the humble words of MisterCMK sent on the go...
Old Dec 15, 2013 | 06:47 AM
  #595
Racer5349's Avatar
Racer5349
Good morning everybody.
Plow looks good Jim, you're ready to work now.
Old Dec 15, 2013 | 09:08 AM
  #596
4.9L's Avatar
4.9L
Morning Minnesota
Old Dec 15, 2013 | 09:17 AM
  #597
wildstang's Avatar
wildstang
VT Chapter Ldr
Have a great snowy Sunday MN. Got around 10" of snow, still lightly snowing
Old Dec 15, 2013 | 09:18 AM
  #598
Bigpipes 35's Avatar
Bigpipes 35
Holy cow that is a big plow for an explorer..
Old Dec 15, 2013 | 09:19 AM
  #599
fordpower88's Avatar
fordpower88
Good morning Jim, Phil, Jim and the rest of MN!
Now ya got a chance to try out the plow Jim.
Old Dec 15, 2013 | 09:39 AM
  #600
wildstang's Avatar
wildstang
VT Chapter Ldr
It is but foe $50 couldn't pass it up. Still need to transfer the back drag from the old one to this one
