Maybe a seized up idler pulley? I've had a couple seize up on our fleet trucks. Try slacking off the belt and moving it by hand. Give the 2 pulleys on the tensioner a spin while your at it, along with all the others if you don't find the culprit.
I think you'd have known it in a hurry if your turbo wheels/shaft was out of whack like that.
Could be several things, but I'd suggest looking at the tensioner first. Make sure it's tight, and not coming apart, even slightly. Search this forum for pics of failed ones.
Mark
My tensioner showed the slightest sign of coming apart(squealed like a bad bearing). Good place to check, mating surfaces should be square with each other.
