As mention on my other posts about white/black smoke.
Is it a good idea to buy a Auto Engineuity Scanner now to test the condition of the injectors? Which model should I buy for Ford 6.0?
It started right up even with the smoke last week, and I drove to work and back home ~ 60 miles last week. I have not start up the engine since. Will it be more damage to the engine if I hook up the AE and run the engine until operation temperature ~20 minute +?
Or just spend the time to do the balloon test with the glow plugs (engine not running)?
I plan to clean up the garage then start the truck up long enough to put it the garage to work on the injector. Seem to me running another 20 minutes might hurt the engine/injectors even more.
Don't know what you mean by "ID scan" the Scangauge II show no code so far. If there a possibility of hydrolock, I will not run the engine to oprerating temp to run the AE test.
Scangauge isn't a very good code reader, especially pending or "soft" codes that haven't set a CEL.
Autozone has a decent code reader.
Do you have SCT tunes? The SCT usually picks up pending codes.
Josh
I have nothing, only ScanGuage II. The truck is stock. Don't even know what SCT tunes mean
I have the coolant filter, and I don't consider coolant filter a modification to the performance of the engine, just a preventive measure for the inadequate oil cooler design.
With it blowing compression into the fuel rail all you're doing is damaging the rest of the injectors AND if you keep overfueling that cylinder you take the chance of melting a piston. I'd think you would have a contribution code from the bad cylinder. Regardless, I'd still pull and reseal all the injectors in that bank. You can clean/polish the spool valves while they're out.
Yes, I will pull and reseal all injectors on the driver side. Just want to make sure that the glow plug balloon test is adequate to determine the faulty injectors.
I also think that while I am at it and if we have the time, pull the other bank to reseal the injectors too, is it advisable?
"I'd think you would have a contribution code from the bad cylinder. Regardless"
So, you are saying go ahead and buy the AE scanner to read the current trouble codes in the truck computer to determine which injector/cylinder compression issues without having to run the engine?
Sorry for the dump questions, since I never seen any of the code reader in real life yet.
