Engine Running Test Trouble
Old Jan 10, 2011 | 06:54 PM
ruffcut88's Avatar
ruffcut88
I can not perform an ERT. The engine shut off when i flipped the switch from hold to test.
The KOEO test worked perfectly.
what do i need to do to be able to do the ERT??
Old Jan 11, 2011 | 04:57 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm not sure how the code reader works, but I know the jumper wire has to be in place before the engine is started when reading the codes manually. Try putting the reader in test mode with the key off, then start the engine.
CamoLaw
Jul 14, 2014 09:15 AM
danocross
Dec 26, 2011 04:06 PM
erts68
2004 - 2008 F150
Mar 29, 2011 09:12 AM
Bruce P
6.4L Power Stroke Diesel
15
Mar 13, 2011 06:28 PM
Dan K Martin
Feb 6, 2004 10:45 AM
