side window replacement
Old Nov 27, 2013 | 09:46 AM
woodtrucker's Avatar
woodtrucker
came out from work and my side door window was shattered yesterday.
Anybody ever had to replace one? is it difficult to? I'm assuming that I'll need to remove the small vent window and unbolt the front guide to fit it in but it would great if I didn't have to do that. I have manual windows so at least I don't have to deal with motors and such...
Old Nov 27, 2013 | 10:31 AM
lindstromjd's Avatar
lindstromjd
Vent window has to come out; the front guide is a part of it. Pretty much everything inside the door will in order for you to fit the new window in there (or at least it did when I changed my driver window). It's not difficult, but it is time consuming and irritating. Make sure you get the regulator all the way down before you attempt anything with the front guide / vent window. And use a good shop vac to clean out the shattered glass, unless you want to turn your fingers into ribbons.
DougofMontana
Jun 22, 2015 10:30 PM
Shamus
Mar 2, 2009 11:20 PM
boilrman
13
Jan 15, 2007 05:29 PM
Cap'n Tea Bag
Nov 10, 2005 03:41 PM
burlii
Aug 26, 2002 07:36 AM
