window cranks bad?
Old Jan 14, 2007 | 06:48 PM
boilrman's Avatar
boilrman
window cranks bad?
I am putting the doors back together in the truck and when I roll down the window, near the bottom the window itself tilts toward the rear of the door. It does this on both sides. I don't see where I can make any adjustments to resolve this. Any ideas? Are the window cranks worn. I have all new weatherstripping installed in the tracks as well.
Any help greatly appreciated.
Thanks
Old Jan 14, 2007 | 07:50 PM
Mil1ion's Avatar
Mil1ion
It still does that with mine.
I should never have had to but, I just Push the window forward when I close it .
Old Jan 14, 2007 | 08:03 PM
73f350sc's Avatar
73f350sc
My guess is a busted roller...or a bent section in the track at the bottom of the window that the roller runs in that allows it to jump out.
-Chris
Old Jan 14, 2007 | 09:05 PM
boilrman's Avatar
boilrman
nothing seems to be jumping out of place. I was just in a yard the other day and rolled a window down to see if it was something wrong or if all windows did it, and that window was working the way I would expect it to. The glass was level when you stopped at the bottom. I have several other window cranks, it is just such a pain to have to take the wing vent loose in order to change them.
Old Jan 14, 2007 | 09:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Question
What year is your truck? I have an idea what the problem is.
Old Jan 14, 2007 | 10:01 PM
boilrman's Avatar
boilrman
sorry, it is a 78
Old Jan 14, 2007 | 11:14 PM
NumberDummy
Smile
Originally Posted by boilrman
sorry, it is a 78
The window glass rides in a felt type channel. This in turn fits into metal channels inside the door frame. The rear lower metal channel has a habit of working loose, from the constant closing of the door.
The head of the bolt that holds this metal channel tight to the door is exposed on the door below the latch. On some models, there is an round painted access cover that pops off to expose the bolt head.
The division bar also has a bolt on the bottom, which also works loose.
Try tightening the bolts up.
Old Jan 14, 2007 | 11:32 PM
boilrman's Avatar
boilrman
All the window felts are new and just recently installed after paint. I know the part you are talking about, everything is tight.
Any other ideas?
Thanks
Old Jan 14, 2007 | 11:43 PM
NumberDummy
Question
Any other ideas?
Thanks
OK..you replaced the felt and the metal channels are tight to the door, and the window regulator is also tight.
How about the horizontal metal channel the window roller rides in, and the glass fits in? There are two pieces of glass tape, inner/outer that keeps the glass tight in the channel. Then there is that pesky window roller that the book says is only serviced with the regulator.
The book is wrong, the window roller is available as a separate part.
D6AZ-5323240-A roller, window channel.
Other than that, I'm stumped.
Old Jan 15, 2007 | 01:53 AM
boilrman's Avatar
boilrman
will look at those things. Thanks for the info.
Old Jan 15, 2007 | 02:08 AM
73f350sc's Avatar
73f350sc
Thats the one I suggested might have a bent out portion in allowing the roller to slip out..
-Chris
Old Jan 15, 2007 | 05:28 AM
boilrman's Avatar
boilrman
Sorry Chris, I missed it. I dont believe it's jumping out, but I will check it out.
Old Jan 15, 2007 | 12:57 PM
Mil1ion's Avatar
Mil1ion
Again, this is common on all these trucks,
Mine has done this with both windows since it was brand new.
It is because of the way it was designed.
The last 1 1/2" you have to push the glass forward to get it to fit properly.
Old Jan 15, 2007 | 05:29 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
My window on the 1973 did something simular, but the window fell into place and rolled right up.
As for window regulators...
Both of the ones on my 73 striped out, and you could use your hand to roll them up or down.
One reason why I swapped doors for ones off of a 1978.
So I doubt it's the regulators.
It was a light blue truck, with off white doors... The cops made me paint the truck, cause it looked like a sherrif's car.
But that's another story...
