Definitely related. You need about 150 cranking RPM's for the PCM/FICM to command the truck to start. Have you checked your cranking voltage and FICM voltage while cranking? Sounds like your batteries may be low or your connections dirty. Check them at the battery, block/frame, and starter. Batteries should be LOAD tested separated from each other.
