Vibration or chatter while turning under load.
Old Nov 25, 2013 | 08:32 PM
bkvanbek's Avatar
bkvanbek
Why do I get a vibration or chatter while turning sharp when I am towing? The bigger the load, the sharper the turn the worse it is.
Old Nov 25, 2013 | 09:13 PM
BLADE35's Avatar
BLADE35
are your hubs locked in??
Hows your U-Joints???
Old Nov 26, 2013 | 07:58 AM
bkvanbek's Avatar
bkvanbek
The hubs are not locked in. I think it is coming from the back.
Old Nov 26, 2013 | 08:07 AM
Money-Pit's Avatar
Money-Pit
Have you changed the rear diff oil recently? Sounds like you may need some limited slip additive in the rear diff.
Old Nov 26, 2013 | 08:27 AM
bkvanbek's Avatar
bkvanbek
That may be, I was thinking that. Recently I had the emergency brake shoes installed and the mech pulled the axes. Soon after the axle cover plate came loose (he had to have forgotten to tighten them) and oil went all over. But when I went to add oil to the diff, it still came out the fill hole.
Old Nov 26, 2013 | 01:07 PM
waterboy_fishing's Avatar
waterboy_fishing
Mine will do that to. Rear differential is trying to slip, designed too. What additive do most of you use. Just curious.
Old Nov 26, 2013 | 06:05 PM
raptor131's Avatar
raptor131
This one HERE
If you buys the Mobil one stuff here, it comes with the additive already in it.
I think you should add only 7 or 8 oz then check if it is still binding. Just enough to let it slip a little .
Superduty ROCKS
Feb 27, 2014 02:38 PM
kc0ti1002
Jun 21, 2010 06:52 PM
Katmandu
1978 - 1996 Big Bronco
Nov 23, 2005 04:00 PM
tombob
17
Jan 2, 2005 09:01 AM
