which solution kit
Old Nov 23, 2013 | 05:14 PM
ed8005's Avatar
ed8005
which solution kit
I have a 2004 f-250 and the head gasket is leaking above the starter. so now i am going to buy a xdp solution kit which head gaskets should i get ? is there anything else i should need besides what comes with this kit.
XDP Powerstroke Solution (XDP EGR Delete Kit, Ford Factory Head Gaskets, Oil Cooler and ARP Head Studs & more)
Old Nov 23, 2013 | 06:21 PM
npccpartsman's Avatar
npccpartsman
18 mm headgaskets
Old Nov 23, 2013 | 06:22 PM
Maxium4x4's Avatar
Maxium4x4
18 mm... Welcome to FTE ed8005
Old Nov 23, 2013 | 07:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Highly doubt the head gaskets are leaking externally... most likely is the $30 orange or blue hose is leaking and running towards the back and then down the passenger head.
Josh
Old Nov 23, 2013 | 08:16 PM
Maxium4x4's Avatar
Maxium4x4
Good point Josh
Old Nov 23, 2013 | 09:28 PM
BLADE35's Avatar
BLADE35
Theres the Coolant Heating element right above the starter to
seen 1 or 2 Freeze plugs leak from Members here
Old Nov 24, 2013 | 11:13 PM
ed8005's Avatar
ed8005
i found the orange cooler hose leaking and lower rad hose leaking to.
i guess i will go egr delete flush and new oil cooler
Old Nov 24, 2013 | 11:39 PM
run6.0run's Avatar
run6.0run
I know where you can get an egr upgrade kit. Lol
Old Nov 25, 2013 | 10:31 AM
Mr.Nobody's Avatar
Mr.Nobody
Well that looks sexy.
Old Nov 25, 2013 | 01:11 PM
Per4mance's Avatar
Per4mance
How much? And did he give you a good deal?
jetact
Jul 15, 2010 05:51 PM
JackedupX82
Feb 28, 2010 07:13 PM
dvldog458
Feb 6, 2010 10:12 AM
salty
Apr 19, 2009 10:08 PM
