International head gaskets
Old Jul 14, 2010 | 09:15 PM
jetact's Avatar
jetact
Has anyone used the International head gaskets? I am buying ARP studs and have not decided a way to go on head gaskets and have not heard much about the International ones. Can you buy them without the bolts?
Old Jul 15, 2010 | 07:35 AM
ehgeeray's Avatar
ehgeeray
The International gaskets and the ford gaskets are identical. Ford simply repackages the international kit. The International kit comes with the bolts as well unfortunately. It is however cheaper than Fords kit.
Old Jul 15, 2010 | 08:34 AM
jetact's Avatar
jetact
Thank you for the input. I see you went with the Black Onyx. Would you go that route again?
Old Jul 15, 2010 | 08:59 AM
matty169's Avatar
matty169
Headsgaskets
Find yourself a Victor-Reinz dealer. That is where people are getting the Black Onyx gaskets. Much cheaper, like $80.00 each set of 2.
Old Jul 15, 2010 | 09:05 AM
olfordsnstone's Avatar
olfordsnstone
$80 each or per set? Just curious.
Old Jul 15, 2010 | 09:30 AM
matty169's Avatar
matty169
Hope this is allowed.......
DCP...800.961.9290
P/N 54450
$44.26 ea.
Old Jul 15, 2010 | 10:08 AM
jetact's Avatar
jetact
Originally Posted by matty169
Find yourself a Victor-Reinz dealer. That is where people are getting the Black Onyx gaskets. Much cheaper, like $80.00 each.
Those are the same as Black onyx? Why are they so much cheaper if they are the same. Just trying to get the best gasket I can so I only have to do this once.
Old Jul 15, 2010 | 11:12 AM
matty169's Avatar
matty169
Price
Those ARE the Black Onyx gaskets. The companies selling them as Black Onyx are just marking them up, and I am sure they wont like this post. If you notice, the Black Onyx gaskets come in a PLAIN wrapper so you dont know who made them. THESE ARE THEM.
Old Jul 15, 2010 | 11:17 AM
ehgeeray's Avatar
ehgeeray
Personally I would go that route but you have to be meticulous when cleaning the head deck and block deck. In my opinion you would never get the surfaces clean enough with the recommend plastic scrapper. You need to use a razor blade to remove all debris left over on the surfaces. The problem is the black onyx gaskets have sealing material on the entire surface and the OEM gaskets only have sealant around the ports so material is allowed to build up on the surfaces. If you reuse stock gaskets you only need to get the sealing areas clean... When I installed my black onyx I had the head surface machined and I spent hours cleaning the block deck just to give you an idea.
Old Jul 15, 2010 | 11:26 AM
matty169's Avatar
matty169
GO TO THE PARTS STORE AND.....
Get the spray on gasket remover. It is VERY strong. Burns your hands, but cleans great. Then I use steel wool.
Old Jul 15, 2010 | 03:20 PM
ehgeeray's Avatar
ehgeeray
I don't know that steel wool is a good Idea... you don't want to use anything that will change to surface finish. Not with this type of gasket anyway...
Old Jul 15, 2010 | 04:58 PM
matty169's Avatar
matty169
steel wool
ultra fine steel wool doesnt remove cast iron. We use it on glass also.
Old Jul 15, 2010 | 05:51 PM
ehgeeray's Avatar
ehgeeray
Nice. Thanks I didn't know that...
