leveling kit
Old Nov 23, 2013 | 12:48 PM
bobby22m's Avatar
bobby22m
leveling kit
I have a 92 f250 2wd and im looking for a leveling kit. Like 2"-3" cant seem to find a kit .that works
Old Nov 24, 2013 | 07:21 PM
MPoulson's Avatar
MPoulson
I had those air sausages stuffed into the front springs of my Bronco plow truck.
Worked pretty good.
Old Nov 24, 2013 | 08:55 PM
bobby22m's Avatar
bobby22m
Worked pretty good.
I would then have to run a air compressor right?
Old Nov 24, 2013 | 09:39 PM
1mouse3's Avatar
1mouse3
he is probably referring to this, the way I installed them on the 71 i had was I rented a spring compressor. use that in reverse to expand the spring and stuff this in, run it as far down/up as possible
Old Nov 24, 2013 | 09:50 PM
mknapik's Avatar
mknapik
That's what in was thinking just saw them at O'Reilly, s today. Weren't bad priced either.
Old Nov 24, 2013 | 09:59 PM
bobby22m's Avatar
bobby22m
Where can i get those?
Old Nov 24, 2013 | 10:05 PM
1mouse3's Avatar
1mouse3
most auto parts stores, they'd be on the self were all the suspension stuff is
Old Nov 24, 2013 | 10:20 PM
mknapik's Avatar
mknapik
O'Reilly has them or at least the one by me does i posted it earlier I thought trying to help you out
Old Nov 24, 2013 | 10:57 PM
bobby22m's Avatar
bobby22m
Ha sorry. I was at work when I read that. I havent seen them there but no knes boughten them since iv worked there.
Old Nov 24, 2013 | 11:10 PM
88beast's Avatar
88beast
those are a saftey hazard they pop out fairly easily, id get a bronco or f150 lift spring any lift company can give ya spring rate data and tell you how tall it will sit compared to your stock spring. or a sd 250 with the coil front may work too
Old Nov 24, 2013 | 11:31 PM
mknapik's Avatar
mknapik
The ones I'm talking about go on the top of the spring not in it .Yea they have them in the section by the vent shades in the aftermarket section at the O'Reilly's by me. And yea I know of the popping out saw it happen a Coue of times at the mud hole of people trying to get a little bigger tire and then it rubbing when they lose it .
Old Nov 25, 2013 | 01:25 AM
bobby22m's Avatar
bobby22m
I found a 88-96 f150 2wd kit 2" leveling kit would that work?
Old Nov 25, 2013 | 05:28 AM
MPoulson's Avatar
MPoulson
$95-$100 and no. You don't need a compressor in the truck.
My old Winebago uses these, stock.
Edit: Also, these don't change the ride...just the ride height. You won't even notice them.
SDTruckMan
2004 - 2008 F150
Jan 19, 2008 11:16 PM
EXX2
May 22, 2007 11:01 AM
viper69
2004 - 2008 F150
Jan 23, 2007 01:06 PM
Ferguson65
2004 - 2008 F150
Mar 18, 2005 04:41 PM
BrianFX4
2004 - 2008 F150
Oct 1, 2004 03:08 PM
