Stalling/Cutting Out During Rain
Old Nov 17, 2013 | 06:40 PM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig
This only happens when it's raining, light and or heavy. Intermittent fraction of a second stall. If am off throttle coming to a stop when it does it then it will die completely. If I traveling down the road when it happens it will just stall for an instant. May do it a few times during the first couple miles and then not do it at all the next several miles, or visa versa. Only thing consistent is that it does it every time it rains and only when it rains. I have checked wires under the truck going to Transmission and even put Bulb Grease in all Transmission connectors and CPS. ?????
Old Nov 17, 2013 | 06:54 PM
Stewart_H's Avatar
Stewart_H
Yeah, that's indicative of a CPS going out. The wipers being on is what causes the interruption.
Changing the ground wire on the wiper motor has proven to help alleviate the problem.
Stewart
Old Nov 17, 2013 | 07:00 PM
Tact's Avatar
Tact
Just recently happened to me. I bet you have an aftermarket CPS. I did, and I switched back to my OEM CPS.
Old Nov 17, 2013 | 07:12 PM
dn29626's Avatar
dn29626
Originally Posted by Stewart_H
...a CPS going out...Stewart
Originally Posted by Tact
...CPS...
....X3....
Old Nov 17, 2013 | 07:56 PM
Bobbys Big Red Rig
Stewart
CPS has just around 1500-2000 miles on it. What's the deal with the wiper motor? Ground it to something else?
Old Nov 17, 2013 | 08:08 PM
Stewart_H's Avatar
Stewart_H
Yes, I should have been more clear.
Move the ground wire for the wiper motor from where it is, to its own separate grounding point.
Stewart
Old Nov 17, 2013 | 09:05 PM
Bobbys Big Red Rig
Stewart
Will give that a shot this weekend. Is it normal for this to show up after years of know problems? Also are certain color CPS's more prone to this than others? I had put a Grey CPS in while trouble shooting what turned out to be a ICP issue, had black in before. Hearing good things about the BW CPS and planning a thread search for more info on different CPS.
Old Nov 18, 2013 | 02:17 AM
4inchlovin's Avatar
4inchlovin
x4 on CPS... If I had to guess I would say your CPS is an SMP
here you go
https://www.ford-trucks.com/forums/9...l#post11677741
Old Nov 18, 2013 | 07:18 PM
Bobbys Big Red Rig
here you go
Well H#ll. Does anybody make a good CPS!!? BW seems to have it's issues too.
Old Nov 18, 2013 | 07:22 PM
Tact's Avatar
Tact
Go to the dealership. If I recall, they weren't that much more than where I got my POS from Autozone.
Old Nov 18, 2013 | 08:04 PM
F350-6's Avatar
F350-6
The discussion of color of the CPS only has to do with Ford or International ones and is pretty much pointless now anyway since the original supplies of black have been exhausted.
There have been numerous reported issues with aftermarket CPS of every different color. If you've got one, try driving around all day with your wipers on when it's not raining. See if you have the same "only happens when it's raining" problems. If you do, go to Ford and buy a CPS.
Old Nov 20, 2013 | 09:14 AM
Bobbys Big Red Rig
My spare is Black so I am in luck on that. It is the one I took out when trouble shooting another issue a few months back. Less than 5k miles on it. May try riding with the wipers before I change it so I know for sure. That's if I can stand the noise long enough.
Old Nov 20, 2013 | 01:33 PM
Brother Les's Avatar
Brother Les
Not so sure that the problem is your CPS per say. I believe that you are getting moisture around the plug in or where is goes into the block. Take out and clean up and put some electric grease to get a good tight seal.
Old Nov 20, 2013 | 07:29 PM
Bobbys Big Red Rig
Did that and it still cut out in the rain. The wipe thing makes sense, just have to confirm it.
Old Nov 23, 2013 | 10:16 PM
Bobbys Big Red Rig
Wiper theory has been confirmed. Only does it when using the wiper delay. Try and move ground tomorrow
cabloom300
Dec 3, 2014 04:18 PM
SSSimon
Australia Chapter
Sep 11, 2014 05:36 AM
cabloom300
Jan 11, 2014 10:43 PM
Reckless
21
Dec 3, 2013 02:33 AM
harris2108
22
Feb 18, 2009 01:16 PM
