What do you think? EOT/ECT DELTA
Old Nov 8, 2013 | 05:48 PM
Green96's Avatar
Green96
I just got off the interstate with my new scan gauge 2 checking my eot and ect. I averaged between 8 and 10 degree deltas. Is this ok? I think they could have been closer but the engine thermostat may need replaced. The warmest it got was 192 and that was under acceleration on the enrltry ramp. It fluctuated between 188 and 185 the reat of the time. What do you all think of this. Thanks.
Old Nov 8, 2013 | 05:51 PM
BLADE35's Avatar
BLADE35
there Great
Change thermostat and recheck
also check ECT and EOT sensors at 12 hour cold soak right upon startup they should be the same temp or 1-3*f of on another
Old Nov 8, 2013 | 05:52 PM
raptor131's Avatar
raptor131
sounds good to me, alot of folks on here recommend the coolant be 190 warmed up all the time. any lower it is defective. some have had to replace several times to get a good one. but your deltas seem spot on, as long as they are within 1 degree of each other after it sitting overnight (coldsoak).
Old Nov 8, 2013 | 07:06 PM
Money-Pit's Avatar
Money-Pit
Looks good, no problems there. As far as the t-stat, it seems normal too from recent discussions. I put a brand new one in last weekend and I run pretty much the same ECT as you. The ONLY time I see 190* or more, is sitting at a stoplight, or WOT. That's with no load.
Old Nov 8, 2013 | 07:52 PM
Misky6.0's Avatar
Misky6.0
If your outdoor temps are cool, like 70 or below i don't think a tstat is worth it for a few degrees. If it is 90 and you had the a/c on then a tstat would prob help.
My .02 anyway.
Sent from my Sprint PC36100 using IB AutoGroup
Old Nov 8, 2013 | 08:05 PM
Green96's Avatar
Green96
Thanks for all the quick replies. I just bought this truck in July without first checking it with a scan gauge and I have been very lucky and pleased with it. Every thing seems to be checking out great so far. I think the only thing that may need to be done is the stc fitting.
Old Nov 8, 2013 | 08:16 PM
Misky6.0's Avatar
Misky6.0
Welcome aboard. Spent a few weeks watching things with the sg2. Voltage on monday am before you crank, to see how batteries ate holding up. Ditto, ficm voltages.
Watch injector, fan, tft, etc. To learn how they act.
Might find something more urgent to do first.
Old Nov 9, 2013 | 07:26 AM
Green96's Avatar
Green96
The fan speed seems fine at about 460-490 rpm at idle and picks up speed fast at acceleration. TFt stays around 147 when cruising unloaded at 65-70 mph. I still need to plug the injector pids into the SG ii.
Old Nov 9, 2013 | 07:44 AM
npccpartsman's Avatar
npccpartsman
That's a lot of fan speed at idle. Mine typically runs around 250 at warm idle......
FWIW--the injector pids are pretty worthless in the SGII.
Old Nov 9, 2013 | 08:05 AM
Green96's Avatar
Green96
I may have to recheck my fan speed. Seems like what I said was correct but I will double check next time I go out.
Old Nov 9, 2013 | 08:15 AM
npccpartsman
If you have an HVAC function that's running the compressor it may alter the fan speed but usually that's only on MAX A/C. I'm betting your ambient temps aren't high enough to cause a "high" fan speed either.
Old Nov 9, 2013 | 08:17 AM
Green96's Avatar
Green96
It was cool last night at about 40* and I had the defrost on which I believe makes the. Ac compressor run.
Old Nov 9, 2013 | 08:23 AM
npccpartsman
It does but I'm not sure that it necessarily affects the fan speed. Try with HVAC off or just floor heat if necessary and see what it reads at idle. FSS has so many parameters that make it run it's hard for me to remember them all--LOL.
Old Nov 9, 2013 | 08:58 AM
jlh542's Avatar
jlh542
Those deltas on your EOT and ECT sound perfect. No problem there.
Angelo190471
Oct 4, 2016 08:19 AM
Subzero68
Jan 26, 2014 11:56 AM
ford dually
1983 - 2012 Ranger & B-Series
Sep 18, 2012 02:37 AM
IT_Dude
Jan 11, 2011 08:36 AM
VHOLT
Modular V10 (6.8l)
16
Oct 29, 2010 05:03 PM
