Truck running cold.
Old Oct 1, 2016 | 10:54 PM
Angelo190471's Avatar
Angelo190471
Truck running cold.
I bought this truck recently and i noticed it seemed to run cool. The needle would be right at n. The pervious owner changed the coolant a couple months ago but put the wrong stuff in. So today i drained it and filled it with red cat coolant. Its now running really cool. This pictures as hot as it gets.
Kinda think it might be missing a thermostat or it stuck.
Anything else it could be?
Old Oct 1, 2016 | 11:32 PM
Macrobb's Avatar
Macrobb
It should run at the N under normal(unloaded) driving conditions; that's around 185-190F where the thermostat opens.
It's only once you start hauling a heavy load uphill for a ways that you start to hit some higher temps.
Old Oct 2, 2016 | 01:21 PM
Angelo190471
So i probably need to change the thermostat right
Old Oct 3, 2016 | 12:34 AM
shorerider16's Avatar
shorerider16
I would suggest double checking the temp through other means, a mechanical gauge or even temp gun before jumping to conclusions. The old factory gauges in these trucks leave a lot to be desired.
That being said, it's not uncommon for the thermostats to get stuck open resulting in a truck that will not come up to temperature under normal conditions. Most here will tell you to only use genuine ford replacement thermostats, I did and have had no issues yet.
Old Oct 3, 2016 | 11:49 AM
Jarkill's Avatar
Jarkill
Some thermostats run on the cool side, Usually the ones bought from the local parts store.
Get yourself a motorcraft T-stat and it will run like shorerider16 said, Just below the middle under normal driving conditions. These engines need heat to better burn the fuel so if it is actually running that cold, it's hard on the fuel economy and probably lacking in the power department too.
Old Oct 3, 2016 | 02:10 PM
Angelo190471
I got 13.9 last fill up and it feels really slow
Old Oct 3, 2016 | 02:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have never paid any attention to the in dash temp gauge. if the heater blows hot and the temp idiot light does not come on, everything is good.
i have seen the gauge show below "N" but blow super hot in winter, and have also seen it hover around "L" and blow almost cold air out of the heater. this was when the truck was almost new. after that i realized that the gauge was useless and the only thing that really worked was the idiot light. it will come on around 230 degrees in my trucks..
Old Oct 3, 2016 | 03:01 PM
Angelo190471
My "heat" is kinda warm
Old Oct 4, 2016 | 08:19 AM
Jarkill's Avatar
Jarkill
At normal running temp that heat should be making you sweat. I think that T-stat is stuck open or not there at all.
Subzero68
Jan 26, 2014 11:56 AM
Green96
Nov 9, 2013 08:58 AM
mblanken881
Nov 27, 2010 07:33 PM
VHOLT
Modular V10 (6.8l)
16
Oct 29, 2010 05:03 PM
Texascadillac42
Dec 21, 2008 07:23 PM
