Stuck in 1st
Old Nov 8, 2013 | 02:17 PM
MP3SONS's Avatar
MP3SONS
Stuck in 1st
I have a 1992 Ford F150 Custom.
The truck will not come out of 1st gear no matter what gear I shift into.
Does that necessasrily mean I need a new transmission?
If not is it a costly fix?
Thanks
MP
Old Nov 8, 2013 | 06:06 PM
Conanski's Avatar
Conanski
And.. which one of the 6 available transmissions might you have?
Old Nov 9, 2013 | 03:58 PM
MP3SONS's Avatar
MP3SONS
Hi Paul...
here is the info on my truck:
the trans is a ZF model, not a mazda
2 wheel drive
5 speed with O/D
4.9 300 cu straight 6
Old Nov 10, 2013 | 07:41 AM
bashby's Avatar
bashby
Does the shifter feel normal? You can remove the shift boot and access the 6-8 bolts that hold the top cover on, then you may be able to see the problem.
Old Nov 10, 2013 | 03:21 PM
Conanski's Avatar
Conanski
2 main possibilities are..
Something broken in the transmission
Clutch not disengaging.
If you can verify the clutch works fine then carefully take the shifter out as bashby suggested and have a look at the parts, not sure on the ZF but some of these have a little composite bushing that the shift lever moves in which can get broken and jambed, if that all looks good then you may have a broken shift fork inside the trans which means the whole trans has got to come out and get disassembled.
Ksanglem
332
Feb 23, 2020 06:42 PM
BigOldBlueTruck
13
Mar 28, 2014 07:16 PM
rocketfootballer
May 23, 2009 03:19 PM
M998
Jan 5, 2008 02:52 PM
SadButTrue
Apr 16, 2000 09:11 PM
