M5OD Mazda 5 speed question
Old Jan 3, 2008 | 02:46 PM
M998's Avatar
M998
I have a 91 F150 with 302 and M5OD trans. I started out a whirring noise in 2nd gear. Then it started getting locked up in reverse. As i was coming home last night I lost 1st and 2nd gear. I would put it in those gear selections and let out on the clutch and it would not go anywhere. So i had to come home in 3rd and 4th gear. Haven't tried 5th or reverse. Scared it would go kaboom! Could it be the shift rails or forks??
Thanks for any help, it is most appreciated
Brian
Old Jan 4, 2008 | 11:49 AM
subs1000w's Avatar
subs1000w
it could be a broken shift fork you would need to pull the top cover to inspect which you can do without removing the trans just need to remove the shifter pull the carpet back and remove the floor trans cover
Old Jan 4, 2008 | 07:18 PM
Clubwagon's Avatar
Clubwagon
Yep, either a broken or worn out fork. You should only have to pull the top cover.
Steve
'95 Clubwagon XLT
Old Jan 4, 2008 | 11:54 PM
M998's Avatar
M998
Ok thanks! I hope thats it. I am going to tear into it tomorrow.
When I took my transmission out last time I just removed the whole shift tower. How does the shifter disconnect from the trans tower stub?? It has a stud with threads on both sides. Do I double nut the longer side to remove it?? Mine had no nut on it. The manual says to take the nut off of one side and put it on the other to remove.
Thanks!
Old Jan 5, 2008 | 01:07 PM
subs1000w's Avatar
subs1000w
that right take the nut off "the short side" and thread it on the long side and it should pull the stud out or you can just remove the 3 small torx and like you did before
Old Jan 5, 2008 | 01:18 PM
M998's Avatar
M998
ok i got the tapered bolt out, thanks
Old Jan 5, 2008 | 02:23 PM
M998's Avatar
M998
What keeps the 1st and 2nd gear in the shift tower from over extending?? I got my tower off and 1st and 2nd gear rail pushed the metal cap out?..
Old Jan 5, 2008 | 02:52 PM
M998's Avatar
M998
ok nevermind. i have a worn shift fork. i got to looking at the cast and the whole side that fits down into the shift ring is gone, then that in turn let the shifter/ shift rail pop the end cap out. trans looks fine otherwise. need a 1st/2nd shift fork. thanks!
msuforeman
Jan 4, 2020 06:41 PM
fisher4life
Sep 30, 2014 08:28 AM
gravydude
Jun 26, 2014 08:27 PM
dawhits1
Dec 20, 2012 09:07 AM
bbdent1
1983 - 2012 Ranger & B-Series
Mar 7, 2004 02:25 PM
