6.0 Oil Cooler leak. Advice/Input needed.
Old Nov 7, 2013 | 05:35 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by Bullitt390
The screw clamp on the EGR is non-factory. Either someone is red necking the factory hose or you have a ghetto EGR delete hose leaking.
Josh
That too. As nasty as the top of the motor is it's hard to tell where it's all coming from. I'm with Bill. Give it a bath and recheck where your leak is. They can travel a long way on top of the motor and almost everything runs down the bell housing.
Old Nov 7, 2013 | 08:56 PM
Jeremy2792's Avatar
Jeremy2792
Alright guys here it is...check out this video!! I had someone start the truck so that I could watch the top of the engine to see if I could find a leak while motor was running after I cleaned it up a bit under there. There is some type of plate directly under the turbo, I have no idea what it is. But if you watch the video you can see the bolt moving with oil coming out, as well as oil/air seeping out from the edge of the plate. Another angle shows what really looks like coolant. I'd like to have your guys opinion on what exactly you think this is. Obviously that bolt needs to be tightened and it looks tricky to get too.
The video absolutely must be watched in 720HD so it's clear and I recommend full screen.
Thanks again guys.
Old Nov 7, 2013 | 09:21 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You have a loose bolt under the turbo...
Josh
Old Nov 7, 2013 | 09:32 PM
BLADE35's Avatar
BLADE35
Ya that could def be the leak with Loose Oil Cooler housing Bolts
Those Loose Bolts Seal the HPO reservoir Gasket and I bet it Pouts oil out with some pedal
Looks like an Oil Cooler job to me
Maybe you could tighten it IDk
Old Nov 7, 2013 | 09:43 PM
Jeremy2792's Avatar
Jeremy2792
Josh
Thanks Josh!! lol
What I am trying to figure out is, what is that plate under the turbo? As you can see in the 2nd half of the video, there's coolant. You can also see oil seeping out from the edge of the plate. Just trying to figure out what that plate is?
Unrealo4's Avatar
Unrealo4
That's one of the Turbo pedastal bolts. It looks stripped to me its just vibrating in place. All that oil all over screams hole in your Turbo to cac tube boot to me. Which is a common problem on these trucks. If the turbos loose it could be leaking oil at the drain tube. But it definitely looks green down there. I would try and tighten if that doesn't work your in for it.
Old Nov 7, 2013 | 09:50 PM
BLADE35's Avatar
BLADE35
oh you guys are right that not the Housing
THOSE Bolts wouldn't cause a Leak
with How Oil mess it is is going to be Hard to find
Old Nov 7, 2013 | 09:52 PM
Jeremy2792's Avatar
Jeremy2792
Unreal, changing that hose tomorrow.
Blade, come again...?
Old Nov 7, 2013 | 09:55 PM
Bullitt390's Avatar
Bullitt390
Looks like the edge of the HPOP cover leaking and also the EGR delete rubber hose leaking coolant.
Josh
Old Nov 7, 2013 | 10:03 PM
BLADE35's Avatar
BLADE35
Josh
THIS^^^^^
Its all such a CHITY Mess looks like it ALL Leaks LOL
Theres A TON of stuff that could leak oil there
You donthave Green coolant do you?????
Just Green dye in OIL Correct???
Arent you supposed to Black Light it?/ to really see the Dye
High Binder
Oct 21, 2010 08:19 PM
chromedom
May 19, 2010 12:19 PM
hacksaw830
Feb 14, 2009 09:02 PM
Dan Steinmetz
Oct 16, 2008 12:26 AM
powerstrokeddiesel
Mar 23, 2008 11:05 AM
