tranny wont shift
Old Nov 4, 2013 | 08:49 PM
trumsey07's Avatar
trumsey07
tranny wont shift
i recently installed a used ip and it lasted about a month so i installed a reman pump and now the truck will not shift into any gear without me manually shifting them. if i put the truck into drive it will not shift into any gear besides 2nd. the truck will not shift into 3rd at all.i have tried adjusting the vrv both ways.i have taken it off and made sure it spun freely. i tried playing with the kick down rod to make sure it was not stuck down and i also made sure the module on the tranny had vaccum,im clueless please help
Old Nov 4, 2013 | 08:51 PM
IDIDieselJohn's Avatar
IDIDieselJohn
If the tranny is indeed getting correct amount of vacuum, then either your VRV is bad, or the vacuum modulator is bad.
Pull the vacuum line off the modulator and if oil comes out of the line, or the modulator, it's bad!
If that's ok, then has to be the VRV.
Old Nov 4, 2013 | 10:31 PM
trumsey07's Avatar
trumsey07
everything worked untill i installed the new ip, what can cause the tranny not to shift at all.
Old Nov 5, 2013 | 09:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
is it getting vacuum to the modulator?
Old Nov 5, 2013 | 11:34 AM
trumsey07's Avatar
trumsey07
its getting vacuum at the vrv,but if u follow the line down to the tranny it does not have vacuum. i double checked the lines and could find or hear a leak.
Old Nov 5, 2013 | 11:35 AM
trumsey07's Avatar
trumsey07
and no oil came out of the modulator,i appreciate all the help this truck is my life line and i just need it to work
Old Nov 5, 2013 | 12:51 PM
tjc transport
i ain't rite
if you have vacuum into the VRV and none out then you have a bad VRV
if i remember correctly the vacuum source should be to the top port, and the bottom port should go to the modulator.
Old Nov 5, 2013 | 04:31 PM
trumsey07's Avatar
trumsey07
im assuming there is no way to manually put the truck into 3rd gear
fkaster01
Mar 10, 2009 05:10 PM
BensDaddy
Washington Chapter
May 26, 2008 10:49 PM
gilllawn
Mar 1, 2008 10:23 PM
Fuzzy
May 6, 2005 11:14 PM
Syntheglass
Aug 11, 2004 08:22 PM
