Little AE code help Please
Old Nov 4, 2013 | 05:52 PM
caverjoe's Avatar
caverjoe
Here are a couple pics of the screens I got. First pic where codes. second pic is a koer test results.
So do I have some bad coils?? along with other problems?
thank you
https://www.ford-trucks.com/forums/a...1&d=1383609053
https://www.ford-trucks.com/forums/a...1&d=1383609080
Old Nov 4, 2013 | 06:56 PM
projectSHO89's Avatar
projectSHO89
You have a cylinder 2 problem, perhaps a bad coil/plug, perhaps a connection, perhaps the PCM.
The rest suggests that the engine wasn't up to temperature and that several of the operator steps in the KOER were omitted.
Old Nov 4, 2013 | 07:26 PM
caverjoe's Avatar
caverjoe
Thank you. Looks like I need to dig down in there and try to find some COP's. yikes
Not really seeing them. oh well I will start yanking stuff off untill I find em
Old Nov 4, 2013 | 09:45 PM
alloro's Avatar
alloro
Remove the covers on the valve covers, the COPs are under them.
Old Nov 4, 2013 | 10:00 PM
pdqford's Avatar
pdqford
But when you find them, don't just replace #2 COP. First swap it with the #1 COP to see if the COP is really the problem.
The P0352 that AE found is indicating that the PCM did not receive a valid IDM (Ignition Diagnostic Module) pulse to indicate that the primary circuit for #2 failed. The #2 COP has a small part to play in that circuit, but as projectSHO89, so does the wiring harnes and the coil driver circuit within the PCM.
So if your lucky, swaping the #2 COP with #1 may prove that the COP was the culprit in the primary circuit if AE then finds a P0351. If not you may want to review this thread:
https://www.ford-trucks.com/forums/1...0-seconds.html
which never posted a final solution
Old Nov 4, 2013 | 10:18 PM
caverjoe's Avatar
caverjoe
not so lucky...
https://www.ford-trucks.com/forums/a...1&d=1383618184
Looks like spark plug blew out. and now that I am doing some digging on that subject I guess it is not uncommon. I think the threads in the head are trash since I can get a plug to start. Found a recommended time sert kit p/n 5553 that comes in just shy of $400. Looks like I can get an OEM COP for about $12 off ebay, not sure what local stealerships want yet. Damn wish there was a place to rent that kit. Oh well guess it could be worse. I will look around before adding another kit to the old chest of tools that Hopefully I will only need one time.
thanks all
Old Nov 5, 2013 | 08:57 AM
alloro's Avatar
alloro
Check eBay. Sometime people buy the kit, fix their vehicle, then sell what's left over. I've seen the kits go for as low as $50 at times.
Old Nov 5, 2013 | 10:06 AM
caverjoe's Avatar
caverjoe
That would be awesome but I have looked with no luck.
Thanks again for all the info
Old Nov 6, 2013 | 06:05 PM
alloro's Avatar
alloro
Bummer, oh well. Perhaps instead you buy the kit, make your repair, then sell the kit on eBay to recover a chunk of change?
Old Nov 6, 2013 | 08:14 PM
caverjoe's Avatar
caverjoe
sounds good but I usually end up not selling tools once I aquire them.
Old Nov 6, 2013 | 09:19 PM
alloro's Avatar
alloro
LOL, you sound like me. I figure if I get rid of it that I'm going to need it again some day.
Old Nov 7, 2013 | 06:44 AM
caverjoe's Avatar
caverjoe
Yep
handifletch
Modular V10 (6.8l)
Feb 11, 2014 08:18 PM
ghig1967
Apr 11, 2011 09:35 AM
UMDSmith
1983 - 2012 Ranger & B-Series
17
Apr 10, 2008 11:49 AM
dirt01
Modular V10 (6.8l)
Aug 31, 2007 02:37 PM
RCRC
1997 - 2003 F150
Dec 6, 2006 06:48 PM
