Sponsored by: Auxito
error code P0355
Old Dec 6, 2006 | 07:31 AM
RCRC's Avatar
RCRC
error code P0355
Hi, new to site..lots of good info. My check engine light came on and got an error code P0355 which is ignition coil "E". My question is how do I determine which coil to replace? What does the letter "E" refer to? thanks. FYI, I've recently replaced the coils on cylinders #1 and #5.
Old Dec 6, 2006 | 08:52 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
The P035* codes start at P0351 for cylinder 1, or like some books or scan tools call it, cylinder A.
A P0355 is for #5 cylinder or cylinder E.
Did you also replace #5 spark plug? It can cause the code.
You could have also got a bad COP (Coil On Plug) or could have a wiring or PCM problem but those are less likely.
Old Dec 6, 2006 | 09:01 AM
RCRC's Avatar
RCRC
I did not replace the plug. I guess I'll try that first and see what happens. Stupid question, but I've never changed a plug on a car. Is it as simple as just pulling the old one out and replacing with a new one?
Old Dec 6, 2006 | 09:37 AM
Racerguy's Avatar
Racerguy
Pretty much that easy but there a few things to be aware of.
For some tips take a look at https://www.ford-trucks.com/forums/1...ce+spark+plugs
Old Dec 6, 2006 | 10:01 AM
RCRC's Avatar
RCRC
Do you have to "gap" the plug. If so, how is this done?
Old Dec 6, 2006 | 10:59 AM
projectSHO89's Avatar
projectSHO89
I'd suggest first checking the connector for the #5 coil. The P0355 fault code indicates that the problem is in the primary side of the coil's circuit. For a plug to cause this particular fault code would require a very specific and somewhat unusual failure mode (shorted).
A quick resistance reading of the coil's primary winding would also be suggested to see if it's open if no othrer faults are immediately visable.
Look at the bright side, at least it's one of the easily accessible COPS!.
Steve
Old Dec 6, 2006 | 11:16 AM
RCRC's Avatar
RCRC
projectsho89, thanks for the info but i am a total novice and don't understand most of what you said other than the connector could be bad. This makes sense since I already replaced the coil. Is this something a non-mechanic like me could do, or should I bring it to someone?
Old Dec 6, 2006 | 06:48 PM
projectSHO89
Uh, make certain it's plugged in...
pop4233
Jan 28, 2014 04:20 PM
2003Navi
Aug 16, 2010 12:35 PM
f250dodgeater
Modular V10 (6.8l)
Mar 1, 2010 02:35 PM
ShowdownAutodotcom
1997 - 2003 F150
Nov 7, 2009 05:53 PM
giles45shop
Jan 22, 2008 09:15 AM
