Modular V10 (6.8l)
OBD CODE READER
Old Feb 10, 2014 | 09:43 AM
handifletch's Avatar
handifletch
OBD CODE READER
I purchased a Memoscan u381 obd code reader about a year ago. It seems to work ok reading codes but my recent plug blow out started as an idle stumble. I am sure that as the plug loosened up, the cylinder was not firing properly but this did not throw a code and the live data did not show anything that I could find. This was an inexpensive unit, but I am thinking this should have shown up. Any idea's?
Old Feb 10, 2014 | 01:21 PM
projectSHO89's Avatar
projectSHO89
Scanner won't help unless you have an actual misfire condition for the PCM to detect.
Old Feb 10, 2014 | 04:16 PM
handifletch
What constitutes a misfire to the pcm. If a coil or plug goes bad will it see a misfire and draw a code?
Old Feb 10, 2014 | 06:42 PM
projectSHO89
A misfire is counted when the PCM fails to detect crankshaft acceleration when it should have.
Codes are only posted when the percentage of misfires out of the total cylinder events exceeds a calibrated limit. If you have an OBD I calibration in your SD, you may NEVER see a misfire fault code.
Old Feb 11, 2014 | 08:18 PM
handifletch
Thanks for the education I appreciate the info. I don't rely on my code reader much, I can usually tell when something is off in performance and sound after 14 years.
t-bone31
Feb 16, 2015 02:55 PM
kynnhoj
Modular V10 (6.8l)
Aug 5, 2009 07:35 AM
yuenglag
1997 - 2003 F150
Oct 18, 2005 10:23 AM
