Sponsored by: Auxito
2002 front dif noise?
Old Oct 31, 2013 | 03:49 PM
93f150guy's Avatar
93f150guy
I have a 2002 f150 5.4 with 3.55 limited slip... For months now every time I hit a bump with the front right side there is a loud bang (sounds like a wore out bushing), and if I am driving slow at an idle you can here a thump every time the wheel goes around. And when I turn all the way it sounds more like a grinding sound.... The noise is getting very bad and I have no idea what it is. I am very mechanically inclined but cannot figure it out. Everything in the front end seem tight. When I lay under it if I get someone to spin te wheel the thump sound sounds like its in the front dif, kinda echoes through the front drive shaft but u joints seem good. I really think it's in the dif, and I'm hoping the banging noise I hear when I hit bumps is the same problem as the noise when the wheels go around.... If anyone has any ideas what could be wrong it would be greatly appreciated, thanks!
Old Oct 31, 2013 | 09:09 PM
enriched&beyound's Avatar
enriched&beyound
might be the lower ball joint? or the sway bar end link?
have you check the gear oil level in the front diff?
Old Oct 31, 2013 | 09:52 PM
steve(ill)'s Avatar
steve(ill)
if it is internal bearings , why would it bang when you hit a bump ? Differential dont know that, suspension does.
Old Nov 1, 2013 | 03:08 PM
93f150guy's Avatar
93f150guy
It's not the ball joint or the end links. And I was thinking maybe there could be a bearing or something where the axle does into the diff that could make a noise if its wore out, every time the suspension moves the axle moves up and down
Pro DIY
Jan 24, 2011 01:16 PM
Mecac
1997 - 2003 F150
Jul 27, 2009 02:18 PM
richard stone
1997 - 2003 F150
Sep 13, 2007 06:41 AM
joshandlauri
Aug 16, 2004 05:38 PM
S_DutyFord
Sep 19, 2002 12:43 AM
