Lower balljoint noise!!! help!!!
Old Aug 15, 2004 | 05:17 PM
joshandlauri's Avatar
joshandlauri
Unhappy Lower balljoint noise!!! help!!!
i've had a few front end noises on the left side. i've replace the upper control arms w/balljoints(both) sway bar links and bushings,shocks (both) and still have a noise a err err noise. i used my stethiscope and the noise sounded like it was the lower bj so i poked a tiny hole in the boot and the noise was not as loud but still there. i'm going to replace it this week. has anyone else had issues with front end noise???
Old Aug 15, 2004 | 05:18 PM
joshandlauri
i poked a small hole and lubed it
Old Aug 16, 2004 | 10:06 AM
buzzard's Avatar
buzzard
My front-end sounds like pop corn popping when making sharp turns. I started a thread a year or so ago and never really discovered why it is making the noise....I replaced lower ball joints, shocks and everything else is tight and lubed. There is no affect on drivability.
Old Aug 16, 2004 | 05:38 PM
joshandlauri
your noise sounds like it in that outer shaft (axle) if its only when turning.
just a guess.
Wynn96
1983 - 2012 Ranger & B-Series
Mar 12, 2010 10:35 AM
MENESLIS
Dec 30, 2005 10:14 PM
jimmc
1978 - 1996 Big Bronco
Sep 20, 2004 09:24 PM
iNFoRMaLiTY
1997 - 2003 F150
23
Feb 27, 2004 11:49 AM
