1986 f150 - $450 (Deerpark)
R control arm is broke .i have one that comes with it i dont have time or tools to fix it.Has bullet proof straight 6 Runs .drives.title and as is
On at least some Ford trucks, there is a rubber bump stop at the top of the pedal pocket. It’s round and on an eccentric bolt that allows you to spin it and raise or lower the clutch pedal.
This is primarily to match the height of the brake pedal, when changes are made, but can serve as a general adjustment as well.
If your truck is so equipped, then it might just need adjustment.
If your truck’s pedal is way off, the bump stop may actually have broken, or fallen out, or been removed by a PO.
1994 Ford XLT F250 Truck 3/4 Ton Super Cab Long Bed 4x4 with a 460 V8 7.5 Ltr Gas with automatic Transmission with Overdrive it only has 83,395 Actual Miles pretty low miles for its age
It runs and drives great it is very clean inside and out has a newer set of tires 4 wheel drive works great when needed just lock the manual Hubs does great in the winter time A/C works heater does also has tool box and rear rack in the back bed with lights is set up for a fifth wheel ball hitch has tow package has power windows locks cruise control CD player radio
Paint and body are in good shape paint has some minor scratches from over the years body has no rust at all pretty straight also no major dents interior is very clean cloth seats are in very nice shape carpet is clean everything works like it should
Engine does not leak any oil transmission shifts great thru all gears brakes are in great shape drives very straight up and down the road is all original never been painted on never been wrecked clear clean title in hand for more info call 509-599-10-09
Beautiful Highboy located in Abbotsford BC. Listed on Facebook Marketplace. $8400. Has a 428. Needs work but comes with a bunch of parts to finish. If only I had more room.....
