Trans Fluid change, Help
Old Oct 19, 2013 | 09:49 PM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Misky6.0
If we drain and fill, then drain and fill again a couple weeks later, we have replaced about 75% (50%, then 50% of the remaining 50%).
If you don't have a heated flush machine that's all you can do.
Originally Posted by BLADE35
My only thought in regaurds to the thermostat is that it Leads to the Cooling line so if we use air to blow that line we can get a lot of the Old Fluid out in that Cooling Loop
Yes, you can get more out that way. It's a good thing to do.
There is no way to get the fluid out of the torque converter.
Granted it wont be All the Old fluid in the Cooling Loop there will still be fluid sitting behind the Thermostat all the way to the Inline filter but the Majority of the Fluid from the Inline Filter threw the Cooler and return line back to Trans will be removed
Why don't you remove the line at the trans and blow all of the fluid out of the line? Why leave what's in the line up to the inline filter?
Old Oct 19, 2013 | 10:03 PM
  #32
BLADE35's Avatar
BLADE35
Originally Posted by Mark Kovalsky
There is no way to get the fluid out of the torque converter.?
Yes I understand
Oh Great Idea I didn't think of that
Since you mention this^^ Maybe I could use a Shop Vac to suck fluid from where the Line hooks up at the trans back into where the Thermostat sits in the Pump??
Maybe this will yield another 1/2qt or so of old fluid out with removal of that line you mention
Its getting Better and better as we work threw this!!Thanks for your help
Old Oct 21, 2013 | 08:42 AM
  #33
Robby Nash's Avatar
Robby Nash
Well I changed my seal, internal filter and external filter on my 04 6.0 this weekend. Boy that external was black and nasty. She took about 8 quarts. I plan on draining in a few weeks and filling again and external filter change. Thanks for the help guys!
Old Oct 21, 2013 | 08:48 AM
  #34
69cj's Avatar
69cj
Yes I understand
Too me you have to balance the amount of work it takes to get that extra 1/2 qt. I don't think the extra labor vrs. the benefit of a 1/2 qt. is worth it. JMHO.
Old Oct 21, 2013 | 09:21 AM
  #35
99ExpyProblems's Avatar
99ExpyProblems
Mine was black as well. Here are the photos from my pan drop about 500 miles after I bought it with 172,500 or so on the odometer. I'm not sure when the last time the Previous Owner changed it. I performed 2 more drain and fills after this pan drop. 24 Quarts total over about 1,000 miles.
Old Oct 21, 2013 | 10:22 AM
  #36
r2millers's Avatar
r2millers
Thanks for sharing the pic's. Strange that it looks like the drain plug isn't at the lowest possible place to drain completely.
I'm not sure that filter is black due to sediment but just from the dark ATF color. Your pan ATF looks pretty clear.
Last time I changed my filter, it looked the same, even though the fluid was clean.
Old Oct 21, 2013 | 10:32 AM
  #37
Robby Nash's Avatar
Robby Nash
Great pics. I wish I took some... Mine looked the same there was lots of sludge there on the magnet.
Old Oct 21, 2013 | 10:38 AM
  #38
Monty Simmons's Avatar
Monty Simmons
I know mechanics who say just leave the transmission alone if it has not be serviced properly. They claim servicing such a transmission will often lead to transmission failure and have seen it happen many times.
I have heard of the same also from other people. Further, I purchased a 2006 F260 5.4 gas engine with automatic transmission with 150,000 miles on it. I took it to have the transmission serviced and these mechanics said to leave it alone; just too risky to mess with.
I did not listen and took it to one of those Quick Lube places with a transmission flush machine and had the transmission system flushed out and fluid changed.
Within a week I started having transmission problems.
Old Oct 21, 2013 | 11:18 AM
  #39
BLADE35's Avatar
BLADE35
Now remember I said I was obsessed
Did you just mean the half qt for that line doing the one line???
Because with very little effort just some air We can get four more quarts of oil out for a grand total of 12 to 13 Court out
Another thought just came to me is what if I blew air into the oil pressure test port that should be after the pump and maybe we wouldn't have to undo that line
Old Oct 21, 2013 | 11:32 AM
  #40
Snuggyworm's Avatar
Snuggyworm
Guys, y'all might already know this. There is a mod for our tranny. Like Benny, I'm also obsessed. *evil cackle.
Change the tranny drain pan to the 6.4 pan, change the external filter setup to straight lines, and use the tranny internal filter for the 6.4.
Pretty much it. Lol. We eliminate the external filter setup, get a deeper pan, and the tranny internal filter is now a screen and an actual filter. Dammit.
Who needs hugs? Snuggy will give u some! But only if I'm on top. Have a great day y'all!
Sent from my iPhone using IB AutoGroup
Old Oct 21, 2013 | 11:48 AM
  #41
BLADE35's Avatar
BLADE35
It probably failed from something in the shop did or did not do
! sounds like it was on its way out anyway
As far as servicing the transmission right that's just the thing
they say it's supposed to be done with a heated flush machine
Nobody can find one and even if they did find a heated flash machine they wouldn't know how to use it
Old Oct 21, 2013 | 12:27 PM
  #42
69cj's Avatar
69cj
Many of the quickie lubes also use generic tranny fluids that are detrimental to some trannys. Haven't seen any around here that stock the LV or SP fluid, so what are they using?
Old Oct 21, 2013 | 12:44 PM
  #43
BLADE35's Avatar
BLADE35
I agree just because the trans didn't get serviced at a regular interval Doesn't mean to forget about it and do nothing
That's probably the worst thing you could do
Maybe I'm just not seeing how proper clean fluid and a new filter could damage it even more
Old Oct 21, 2013 | 01:13 PM
  #44
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Wow... You guys are waaaaaaaay over thinking this.
Some of you guys have taken 10 years just to drive 30,000 miles LOL
Kind of funny when a million dollar excavator when changing the hydraulic and hydrostatic fluid, even if you drain 100 gallons there is still 30 gallons in the system. Does Deere or CAT care? Nope, dump n fill and move on.
Josh
Old Oct 21, 2013 | 01:17 PM
  #45
69cj's Avatar
69cj
Josh
YAAAAAAY Josh.
