Trans Fluid change, Help
Old Oct 19, 2013 | 12:49 PM
Fird's Avatar
Fird
Originally Posted by Mark Kovalsky
It's very accurate FOR A 4R100! It will NOT work on a TorqShift. I should know, I wrote that procedure that they stole without attribution.
Hmmmm well that settles that...and disregard my previous post.
Thanks.
Old Oct 19, 2013 | 01:07 PM
r2millers's Avatar
r2millers
From all of us out there, here's your attribution.
Thank you very much Mark for all this expertise, both on FTE and the results, in our trannies.
Always look forward to your comments.
Old Oct 19, 2013 | 01:11 PM
BLADE35's Avatar
BLADE35
Nobody knows???about this machine???
Is it a Top Secret Ford Document or something LOL
Old Oct 19, 2013 | 01:18 PM
big inch's Avatar
big inch
I believe very few dealers have a heated flush machine. I don't know of any in my area that have one.
Fwiw, I don't see why it wouldn't work. If it keeps the valve open, so that the fluid keeps flowing through the cooler, the majority of the fluid will be exchanged.
Old Oct 19, 2013 | 01:38 PM
lupuseven's Avatar
lupuseven
'03-'07 we do not need to change the internal filter.
So I am curious should or can we "rinse" it out. It would seem at some point it would collect something, and eventually layer over with it.
Of course I am thinking with that internal filter screen having such "large" holes if it does catch a lot then there would be bigger issues?
Just curious not trying to cause trouble. :-)
Old Oct 19, 2013 | 02:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The internal filter keeps trains from running thru it......
Old Oct 19, 2013 | 03:31 PM
diesel_dan's Avatar
diesel_dan
OP: here's a thread you might find interesting....
https://www.ford-trucks.com/forums/1...ns-filter.html
Old Oct 19, 2013 | 03:36 PM
bismic's Avatar
bismic
Not true. See above.
Not all 2008 trucks are like this. See above.
The 2008 trucks do not have 6.0's in them. Since this is a 6.0L forum, I stick by the earlier statement as it applies to trucks.
I assume you are informing us that the 2008+ E-series are different? (I stand corrected on that - I just am not in the mode to think about the E-series).
Old Oct 19, 2013 | 05:01 PM
69cj's Avatar
69cj
Don't exagerate, more like trees and boulders.
Old Oct 19, 2013 | 05:53 PM
BLADE35's Avatar
BLADE35
Just read thru that and I did LIKE what I saw Mark Job well done!!
You did address some concerns I had in the writeup Like shifting of the gears and actuating the silinoids ect.... You Even made mention of using More trans fluid to make shure all the Old fluids are Expelled out what makes complete sense to me
Can you expand on why it wont work for out 5R110w??
I'm thinking that the Thermostat is part of the reason that procedure wont work on a Torqshift trans???
So in regaurds to the thermostat it did make mention of Blowing air into the Cooler lines to expel Old Fluid Out
What else would be a Concern with your write up if the procedure was used on a 5R110W
Its just like Big Inch mentioned these "Hot Flush machines" are hard to Find AND Probably even harder to find a Tech that would do it correctly
I'm just trying to Adopt a Trans fluid change procedure that would Expel the Most Old Fluid out and then just Increase the change interval some
Old Oct 19, 2013 | 07:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Good point. I was just referring to the TorqShift, which is essentially the same in the 6.4L.
No, they are not different.
That is the only reason it won't work on a TorqShift.
That won't affect the thermostat in any way. The thermostat is in the pump body, not the cooling lines.
My only concern is that it won't work due to the thermostat recirculating fluid instead of sending it out the cooler line.
Old Oct 19, 2013 | 07:39 PM
bismic's Avatar
bismic
Mark - do you know the mesh size for the internal filter? I know we (forum folks) say it is for boulders, but that is true only in comparison to the external filter that filters down into the micron size.
Old Oct 19, 2013 | 07:50 PM
  #28
Misky6.0's Avatar
Misky6.0
Mark,
Are we are overly obsessed with trans fluid changing..
If we drain and fill, then drain and fill again a couple weeks later, we have replaced about 75% (50%, then 50% of the remaining 50%).
If you tow "a lot" maybe do another drain/fill and you are good, with 87% fluid changed.
If you shorten the flush interval a bit that will help too.
I paid $140 for a "flush" when I bought it used at 98k but they only used 7 qts. So, i plan on doing drain and fills so i know what is being done.
I also have the "upgraded trans pan with the internal filter" ready to go in 1000 miles @130k
Thanks for all your expertise.
Sent from my Sprint PC36100 using IB AutoGroup
Old Oct 19, 2013 | 08:02 PM
  #29
BLADE35's Avatar
BLADE35
My only thought in regaurds to the thermostat is that it Leads to the Cooling line so if we use air to blow that line we can get a lot of the Old Fluid out in that Cooling Loop
Granted it wont be All the Old fluid in the Cooling Loop there will still be fluid sitting behind the Thermostat all the way to the Inline filter but the Majority of the Fluid from the Inline Filter threw the Cooler and return line back to Trans will be removed
Old Oct 19, 2013 | 08:09 PM
  #30
BLADE35's Avatar
BLADE35
Originally Posted by Misky6.0
Mark,
Yes Im Obsessed LOL
But here is a Great Example^^^
You had a Flush Done and only got 7 qts of New fluid in it Aprox 1/3 of the old fluid changed
Well with Very little effort and some compressed air Blown into the lines when the inline filter is taken off I was able to get 12qts out and 12qts Fresh fluid in
SO Instead of 1/3 New Fluid I got 2/3 New fluid in it all at the Same time!!
I was shocked how much more fluid I got just with Blowing some air into the Line
