Sponsored by: Real Truck
Trans temp sending unit replacement?
Old Oct 18, 2013 | 10:24 AM
horsez2go's Avatar
horsez2go
Hi y'all,
The trans temp guage on my '08 F-350. V-10 started acting erratically, and the wrench icon popped up on the display. i crawled under the truck to look for the sending unit and it's lead. i assume that i found the lead. it is encased in a corrugated sleeve, and appears to be a vaccuum type tube and boot connector? the boot still had a small round gray cap plugged into it. it appears that the cap was never glued (go figure) upon assembly. i have tried to reach up on top of the trans to find the sending unit to figure out the best angle of attack. i can barely touch it with the tip of my finger. going with mechanical guages is out of the question at the moment, so i'm wondering can it be driven any distance this way, AND any schmooze tricks that anyone has developed to get at the sucker without dropping the cross member or exhaust????
Old Oct 18, 2013 | 11:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Uh, no, don't do that. You have found one of the three speed sensors. Changing any of those will not help you.
The temperature sender is inside the pan. Once the pan is off it is easy to change the sender. It is called the TFT (Transmission Fluid Temperature ) sensor.
You can drive the truck the way it is. It may go into a protect mode.
Old Oct 18, 2013 | 01:31 PM
horsez2go's Avatar
horsez2go
So that line that I found is a speed sensor? located on top of the tranny, back by where the transfer case bolts up? is that a pain to replace? I can drop the tranny pan and replace the temp sensor with no problem. at 134K it needs a service job anyway.
Old Oct 18, 2013 | 08:37 PM
Mark Kovalsky
It is rather hard to get to the three speed sensors on top of the trans. It can be done, but it isn't as easy as the temp sensor.
nelstone74
Jul 1, 2007 08:42 PM
bigtorque
Mar 18, 2007 02:13 PM
Grunt99
Sep 17, 2006 09:53 AM
Ultraute
Jun 27, 2005 10:25 PM
Biwanylo
Oct 11, 2003 07:26 PM
