Uh-oh... those are symptoms you can get with tired injectors. Odo reading?
You'll want to record your AE data while the truck is under max load. A WOT test for at least 5 seconds will do, or towing at WOT, or climbing a grade at WOT will show what the truck is capable of - or not. AE PIDs you want to record:
Remember that more recordings will write over the first one taken on the same day, so be sure to name each recording differently if you do more than one.
