Do all Diesels lack power after a cold start up?
Old May 31, 2007 | 03:12 PM
captaincook's Avatar
captaincook
Or is this something else? It sat all day and night. I cranked it up and headed down the road. It hardly had any power until it got warmed up...then she ran like a top. Just curious. Thanks for any info!
Its a 2003 F250 FX4 6.0 Turbo Automatic.....
Old May 31, 2007 | 03:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
All vehicles run much better after the necessary warm up period. I would never ask a cold engine to perform until it is at operating temperture!!
Old May 31, 2007 | 03:36 PM
F250Wheels's Avatar
F250Wheels
I have less power when cold after my last flash.
Old May 31, 2007 | 03:38 PM
UGA33's Avatar
UGA33
Mine starts out a tad sluggish when its cold but as soon as it gets close to normal operating temps she comes alive
Old May 31, 2007 | 03:40 PM
Beerstalker's Avatar
Beerstalker
How cold are you talking?
I had a similar experience one time over the winter when it was -20°F, the truck was really sluggish and would only get up to about 30mph. You could put the pedal to the floor and it just wouldn't do anything. Only lasted a minute or so and then everything was fine. I think the oil was just so thick from the extreme cold the injectors weren't working right.
If it is doing this in weather above freezing then I think there is something wrong.
Old May 31, 2007 | 04:04 PM
winged1dur's Avatar
winged1dur
Mine was sluggish on cold days until I put in synthetic oil at 10,000 miles. What a difference!
Old May 31, 2007 | 04:36 PM
aladin sane's Avatar
aladin sane
I find I don't have much power after a cold winter start. I came home from a business trip this past winter. While I was away, there was a thaw followed by a deep freeze (below 0 F). My tires where frozen to the pavement of the airport parking lot by about two inches of ice. Until the engine warmed up a little, I could not break free from the ice.
Old May 31, 2007 | 11:47 PM
captaincook
Well I should be more specific when I say cold. I meant the motor hasnt ran in 18-20hrs and I live in North Texas. Roughly 80 degrees when I started it, put it in drive and went. Felt like I think a Chevy would................NADA.....I let it sit the same amount of time today, cranked it up and let it idle for a few minutes and off she went like normal.
Old Jun 1, 2007 | 12:25 AM
Beerstalker
If it was 80 degrees out and did that then I am afraid you may be starting to see injector stiction issues. Do you have either of the latter two flashes that add the buzz after shutdown or heat the injector sppols?
You may want to check out the thread about Hot Shot Secret. This supposedly is designed specifically to hep with injector stiction issues.
https://www.ford-trucks.com/forums/6...-additive.html
Old Jun 1, 2007 | 12:26 AM
rollerstud98's Avatar
rollerstud98
mines a bit sluggish in the morning usually
Old Jun 1, 2007 | 12:43 AM
blackhat620's Avatar
blackhat620
captaincook,
As Beerstalker said, you are having injector stiction issues. How many miles on the truck and how often do you change the oil?
Old Jun 1, 2007 | 05:31 AM
Superdudey's Avatar
Superdudey
what does the buzz do? I have that......
Old Jun 1, 2007 | 08:02 AM
captaincook
Ive only had the truck for about 10 days. It has 80,000 miles on it. The guy I bought it from claimed he changed the oil every 5,000 miles (who knows) I do know it needs to be changed right now, its about 100 miles over 5000.
Old Jun 1, 2007 | 12:28 PM
blackhat620
The "buzz strategy" and the newer "heat induction strategy" are used to accomplish the same thing, help prevent injector stiction issues when the engine is cold.
The "buzz strategy", cycles the spool valves to eliminate any oil that has pooled around them, when you turn the truck off and you hear a buzzing sound for about 30 seconds while this process is ongoing.
The "inductive heat strategy" uses electicity to heat the injectors and oil around the spool valve when the truck key is turned to on and continues this process for about 2 minutes after the engine is started.
Both strategies accomplish the same thing in different ways. IH still uses the "buzz" strategy in there trucks and FMC switched to the "inductive heat" strategy.
Old Jun 1, 2007 | 12:31 PM
blackhat620
First thing is change the oil and filter, i would also change the fuel filters. Then see if this helps at all. If you still have the problem, take the truck to the dealer and tell them you are having cold start issues, they can diagnose the problem and perform a cylinder contribution test to check the injectors. Also they will update your PCM to the latest program which will give you the "inductive heat" strategy and the newest EGR & EBP strategies. All of the new programming features are a good thing for your motor. Since your engine is covered by the 5/100K warranty this will only cost you the $100 deductible.
Good luck
