Any Blue Spring Mod negative effects?
Old Oct 16, 2013 | 10:12 AM
Robby Nash's Avatar
Robby Nash
I have an 04 F250 6.0 that is for the most part stock with 200,000 miles and runs great. I'm considering doing the blue spring mod but worry if there are any negative effects they can have on a truck. I kind of live by "If it aint broke don't fix it" however if this is a good mod and people have good luck with injectors lasting longer and the truck running better with more fuel then I want to do it. This is an OEM and not aftermarket upgrade so should there not be any worries?
Old Oct 16, 2013 | 10:27 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I's really just manufactures update addressing some weak springs, I wouldn't even call it a mod. Won't cause an issue if properly installed.
Old Oct 16, 2013 | 10:36 AM
MC5C's Avatar
MC5C
As Rusty says, it's a factory update, not a modification. The standard spring in the pressure regulator is set up for the E-series van motor and the International motors, both of which are calibrated to significantly less power than the 6.0 in the F series. The pressure just falls too low, and the injectors die. I consider the updated spring a mandatory change, not optional at all.
Brian
Old Oct 16, 2013 | 10:37 AM
Robby Nash's Avatar
Robby Nash
Ok I got ya. That's good to know.
Old Oct 16, 2013 | 10:46 AM
Robby Nash's Avatar
Robby Nash
So with this Blue spring would I notice better throttle response, gas milage or anything like that?
Old Oct 16, 2013 | 10:49 AM
Rusty Axlerod
Possibly, but only if the pressure was low with the old spring.
Old Oct 16, 2013 | 12:21 PM
diesel_dan's Avatar
diesel_dan
The only downside, as Rusty pointed out, is if you do it wrong. It is very easy to put the spring in, but since you have an '04 IIRC, there was a change around then as to the poppet valve and a seal. Take a close look at how your parts come out of the pressure regulator. I'd have to go look, but this may be covered in the tech topic on installing the Blue Spring.
Best place I found to buy what you need, kit-wise, is from Riffraff -- nice folk (you don't need the kit with the cover unless yours is cracked.) Here's a link:
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
Old Oct 16, 2013 | 05:32 PM
Rusty Axlerod
Apparently, if you regulator housing uses this piece (the one it the picture does not) there is an o-ring that goes on it before putting it in the housing. If you leave the o-ring off, the truck will run but it can make a noticeable buzzing sound in the regulator.
Blue spring install
https://www.ford-trucks.com/forums/1...ue-spring.html
Old Oct 16, 2013 | 07:08 PM
Yahiko's Avatar
Yahiko
Lets see
Saves injectors and that saves you money.
OOPS you said negative.
Sean
slowlanemcvane
Oct 1, 2014 11:37 AM
waterboy_fishing
Dec 20, 2011 09:38 AM
sflem849
Apr 1, 2008 10:55 PM
jimwilsonmasonry
Feb 7, 2008 08:29 PM
Robbgt
Dec 22, 2004 08:56 AM
