Sponsored by: Real Truck
Headlight Conversion Question
Old Oct 13, 2013 | 03:59 AM
GamerGirlAlice's Avatar
GamerGirlAlice
ty for the advice on this idea. they do make a glass housing that uses a h4 bulb and retains the sealed beam look. puts out 2wice the light of a sealed beam too. should i just consider something like the h4 conversion?
Old Oct 13, 2013 | 04:54 AM
Yahiko's Avatar
Yahiko
I personally like my HIDs. But I do have an 06.
I had an 88 Ranger that I used the glass Hella
headlamp units. They had a true metal reflector
and used the H4 lamp. 100% incandescent and
I think that would fit in your current housing.
FRSPORT 1140 FR Hella H4 Headlight Conversion Kit RPS13 S13
In the Ranger I did install a set of relays. I had done a little wattage upgrading and
was burning up the headlamp switch and the hi/low switch. Add a set of relays and fuses.
Problem solved.
Sean
NOTE : Do you have a link to the page for the kit you just showed?
Old Oct 13, 2013 | 05:06 AM
GamerGirlAlice
Problem solved.
Sean
so it is a worthwhile upgrade it sounds like then. i know h4 are out there as well as hid. so i do have lots options i suppose. seen some with integrated led turns as well
Old Oct 13, 2013 | 05:27 AM
Yahiko's Avatar
Yahiko
The H4 kit was so much of an up grade it was like night & day
when you compare it to the sealed beam units.
I feel that the key was the metal reflector.
They also had a very good beam pattern with sharp cutoff.
So that your not putting light where it's not needed.
Sean
Old Oct 13, 2013 | 06:04 AM
tjc transport's Avatar
tjc transport
i ain't rite
don't worry about the adapter plug, ford used them from the factory to convert the electrical system of that truck to accept the seal beam lights. i have 3 sets of adapters in the garage from parts trucks i have bought and stripped.
Old Oct 13, 2013 | 06:12 AM
GamerGirlAlice
so the stock 3pin plug is a adapter for the normal composite? does that mean i can unplug it to put in composite headlights?
Old Oct 13, 2013 | 06:22 AM
tjc transport
i ain't rite
if i remember correctly you take the sealed beam adapter off and the remaining plug will plug rite into the composite lights.
Old Oct 13, 2013 | 06:27 AM
GamerGirlAlice
that would be super convenient if true
adam Thatcher
Nov 7, 2017 04:30 PM
soundwave
2009 - 2014 F150
Mar 16, 2010 11:39 PM
7.3 Rocket
13
Jan 4, 2009 09:44 PM
Ranger73
16
Aug 20, 2007 09:48 PM
CentralCoaster
2004 - 2008 F150
Sep 1, 2005 11:51 PM
