Coolant filter questions.
Old Oct 10, 2013 | 07:45 PM
Ryandee18's Avatar
Ryandee18
So I am going to buy the nampa filter kit, cheaper. My question is what is the best way to install it as far as splicing in the lines? I have heard lots of ideas people have. I don't mind an in line application apposed to bypass. Also if I got a four hose fitting, to take in more flow. Don't have a clue.
I don't mind heater stopping when filter is clogged, I can just change it. Can the filters handle the flow? The best set up is what I'm looking for.
Thanks in advance!
Truck is 2006 f250 cc lb. 83.5k
Old Oct 10, 2013 | 07:57 PM
retiredinstructor's Avatar
retiredinstructor
check out the tech folder there is an excelent do it yourself article , they are using napa parts
Old Oct 10, 2013 | 10:02 PM
BryanStein's Avatar
BryanStein
It takes a massive filter to run it in line without slowing the coolant flow to the point of running the engine hot.
Old Oct 10, 2013 | 10:37 PM
BLADE35's Avatar
BLADE35
But the Heater Loop is a Bypass anyway
He cant or Shouldn't set it up with an Inline heater Filter because it wont Filter anything with Max A/C ON See the Valve circled in RED Below in the First Pic that STops the Flow when A/C ON
I used a Napa Kit with Pex fittings Tyed in same but the return on Mine is Different it Don't reduce to that Small Line
You can only filter as much as the smallest fitting will allow
I drill the Inlet in the filter out and Tyed the return into the Heater Return line
IPR makes a kit that filters 100% flow before the Oil Cooler but its spendy
dlibson
Jun 3, 2014 09:00 AM
2500ak
18
Oct 30, 2013 01:25 AM
DieselVol
Aug 13, 2012 01:49 PM
75diesel
Jul 22, 2012 11:11 PM
F0rdF0rever
Mar 19, 2008 05:25 PM
