Shop Time
Old Oct 10, 2013 | 03:30 PM
bvan00's Avatar
bvan00
Shop Time
Can anybody give me and approx. time of the labor hours a repair shop should charge to replace an egr cooler and two injectors? Any response would be appreciated. Thanks
Old Oct 10, 2013 | 06:06 PM
BLADE35's Avatar
BLADE35
you should replace the Oil Cooler if you have EGR Cooler issues
your probably looking at 2000-2500 coin to do this this is Only a Guess
Some the other guys Know Book times
Old Oct 10, 2013 | 06:46 PM
69cj's Avatar
69cj
Benny's correct. Bad egr cooler = bad oil cooler. Don't procrastinate or the repairs will escalate.
Old Oct 10, 2013 | 08:07 PM
big inch's Avatar
big inch
It has been a long time since I have done just an oil cooler, but I would guess it should be about 5 hours of labor. The injectors would be about 3 hours if on the same bank.
Like the other guys said, the oil cooler should be replaced with the egr cooler. To do both coolers and the coolant flush, etc should run around 12 hours.
Old Oct 10, 2013 | 10:54 PM
Bruin008's Avatar
Bruin008
If you have the proper tools, which is nothing more than sockets, torx bits, extensions and to make things easy, air tools and swivel sockets, then this job can be accomplished by yourself. It will save a good bit of coin.
imcqueen
Nov 16, 2017 04:50 PM
craziejoker
Nov 13, 2012 02:46 PM
run6.0run
Nov 3, 2012 08:01 PM
duallytime
Oct 15, 2010 09:17 AM
scameron
Feb 2, 2009 04:15 PM
