Emergency Brake Failure
My vehicle is a 1999 F-250 SD w/standard trans.
Last night pulled into the driveway and tried to set the emergency brake pedal as usual. This time there was a loud bang and the pedal went to the floor fast. I checked all the cables front to back and none are broken. So the failure must be in the brake control assembly. The assembly is special order from the dealer at $161.
My question is how do you get the old one out of the truck? There appears to be some kind of connection/computer box right up against the assembly so you can't even see all the bolts holding the assembly in place. Is there any special technique in getting this brake assembly free from the truck. The manual is not very helpful.
Thanks for inputs--Jerry
Not sure which engine you have but the general procedure is to ensure the keys are out of the ignition. For extra precaution...disconnect the negative battery cable(s). If dual battery, then remove both negative cables.
From the engine compartment, loosen the 10mm hex drive bolt that secures the PCM connector to the module. The bolt won't come completely out....so just loosen it until the entire connector can be separated from the module.
From inside the cab, remove the two 8mm hex drive bolts that secures the plastic carrier for the PCM and remove. Then grasp the PCM and rotate the non-plug side towards the clutch pedal and then pull the module out.
With the module out of the way you should be able to access the parking brake pedal assembly.
I just need to find a welder. You guys are excellent.
You could also use a MIG and you can get that there too.
You other option is Harbor Freight if you have one near.
Sean
Got another question. Does the wiring harness pull away from the fire wall (end which is under the hood) when the PCM is removed from under the dash? The photo of the PCM in the manual shows many connector pins on the PCM. How easy is it to re-insert the PCM back into the harness connector?
Thanks for your help--Jerry
