Parking Brake
Old Mar 14, 2003 | 10:17 AM
straight 6's's Avatar
straight 6's
Exclamation Parking Brake
okay there is a linkage from the parking brake it is where the cable goes from one and splits into left and right. this broke then bent, so i heated it bent it and migged it. now i can't get it back on i can't pull the cables far enough. Does anybody know if ther is an adjustment where i can lenghten the cables?
i already tried to one at the pedal. i have a 92 creww cab regular box. After 2 months of driving around with it.....IN MY TOOL BOX i'm really starting to get bothered by it.
tanks for any suggestions
Old Mar 14, 2003 | 02:23 PM
winfordr's Avatar
winfordr
Parking Brake
Assuming your fix didn't make you need a longer cable, you just have to pull hard on the brake cables to snap it in place. I had a bad cable and had the same problem replacing it. You may have to enlist some help, so one person can pull on the brake while the other snaps it in.
I assume you do have the pedal released.
Old Mar 14, 2003 | 06:34 PM
steve83's Avatar
steve83
Parking Brake
On '92-96, there's an auto-tensioner built into the brake pedal that's supposed to reset every time the pedal is fully released, but I'm not sure how it works. Try pulling the pedal hard up and then pull the cable out under the truck.
Old Mar 14, 2003 | 07:42 PM
Racerguy's Avatar
Racerguy
Parking Brake
On some 92-94 trucks there was a recall on the park brake pedal. The fix involved putting a locking wedge in the ratchet assembly on the pedal. It made it so it didn't automatically adjust anymore. If this was done to your truck you wont be able to just pull the cable out under the truck. You have to remove the locking wedge first. If I remember right the wedge is a white (I think) piece about an inch or inch and a half long and fits in between the teeth on the ratchet in the pedal assembly.
Old Mar 17, 2003 | 08:42 PM
straight 6's
Parking Brake
racer dude you the best i nvr thought of that i just had that recall taken care of. nope my fix din't have anything to do with the cable i just put things back the way they are supposed to be. i made a custom thingy to pull the two ends together to fix this put cable doesn't stretch very far . yah the pedal was released i do have one question though if i do pull the wedge out(yes it's white) willi be able to get it back in
Old Mar 17, 2003 | 08:48 PM
Racerguy's Avatar
Racerguy
Parking Brake
Yup you should be able to get the wedge back in. Pay close attention to how it goes in, maybe mark where it goes so you get it back in the exact same spot.
80F250cust
1997 - 2003 F150
Nov 11, 2011 03:21 AM
CNC
May 5, 2009 05:04 PM
CNC
Apr 25, 2009 03:23 PM
cies_69truck
Dec 27, 2005 09:16 PM
MustangGT221
Jun 15, 2003 12:19 AM
