Urgent Part Identification Please Help
Old Oct 8, 2013 | 10:16 AM
h20_guy33's Avatar
h20_guy33
This ties the hoses together for the heater on the passenger side of my 01 v10 ex. Plastic. Anyone know what its called?
Old Oct 8, 2013 | 10:47 AM
h20_guy33's Avatar
h20_guy33
nm, its a heater water control valve
Old Oct 8, 2013 | 12:57 PM
Stewart_H's Avatar
Stewart_H
Yeah, it's a vacuum actuated heater control valve.
When you turn your AC to the MAX setting, that valve stops the coolant from flowing through the heater core, which allows the AC system to cool the air a few degrees more before coming through the vents.
That valve was not put on the 7.3L trucks, so F250/350 owners will sometimes do the AC Mod and add the valve.
Stewart
Old Oct 8, 2013 | 04:02 PM
housedad's Avatar
housedad
Yeah, they break regularly. I've had to replace mine twice since I bought the Excursion in Nov 05.
Old Oct 8, 2013 | 07:18 PM
h20_guy33's Avatar
h20_guy33
thanks guys. Most of my mechanical experience is with older mustangs and hot rods. never seen one of these things before. Would think that ford might have made it out of something more durable than plastic.
Old Oct 8, 2013 | 08:52 PM
EXv10's Avatar
EXv10
They could have left it out or you can bypass it. I don't use the Max anyway. Just an idea some engineer had and they ran with it.
Old Oct 8, 2013 | 09:15 PM
h20_guy33's Avatar
h20_guy33
I live in Florida so I use Max often. I understand its purpose, it was just done on the cheap.
Old Oct 10, 2013 | 06:00 AM
DSN46's Avatar
DSN46
Not trying to hijack the thread, but I have a question that is relevant.
The by-pass on my Ex is the type that has the "armature" thingy with hinges and the vacuum pushes or pulls the armature rod in and out of a little canister. I had to go to the dealer and pay more for that exact part than the box stores wanted for the mushroom-looking one in the picture above.
Question is: would the one pictured above (minus the bottom hose on it...they make them without the bottom hose attachment point) work in place of the expensive one from the dealer? I only ask in case I have to do this again.
Thanks!
James
Old Oct 10, 2013 | 06:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
YC3Z-18495-BA .. Heater Water Control Valve w/o auxillary heater.
MSRP: $66.98 / FTE sponsor tousleyfordparts.com price: $35.16.
Tousley Ford now AutoNation Ford, located in White Bear Lake MN
Old Oct 10, 2013 | 09:28 AM
1 Excursion camper's Avatar
1 Excursion camper
To answer the above question, the one with just 2 connections just stops the water flow. The one with 3 connections redirects it back to the motor/radiator. Some manuf. like the 2 way connections and some like the 3way!.........ya i know apparently ford likes a 3-way!
Old Oct 10, 2013 | 10:24 AM
az_r2d1's Avatar
az_r2d1
uh..? Isn't the 3rd one for the rear ac/heating unit ?
Old Oct 10, 2013 | 11:58 AM
DSN46's Avatar
DSN46
Thank you for the reply.
I don't think I made my question clear though. I know what the third hose is for, and that system doesn't exist on my 05 Ex. The question was, would the valves shaped like the one above (only with two hoses) work the same as the one that came on my Ex from the factory? If no one knows the type of valve I'm talking about, I can try to get a link to a picture of one. It is more like a drum that is laid on its side with a diaphragm inside that pushes and pulls a linkage rod that opens and closes the gate.
Thanks again!
James
sboyd2224
1983 - 2012 Ranger & B-Series
Jun 8, 2011 10:10 PM
Mike8623
Dec 30, 2008 05:39 PM
timothy47129
Nov 25, 2006 04:28 PM
Douglas DC-9
May 29, 2006 10:40 PM
bulrydr_1
Feb 4, 2005 06:52 PM
