Radiator coolant filter ?
Old Jun 18, 2003 | 09:47 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Anyone have information on coolant filters? I have heard of one that used mesh screen in one of the coolant hoses. Does anyone have any information on how I could make one. Any information would be greatly appreciated.
Old Jun 19, 2003 | 09:42 AM
steve83's Avatar
steve83
Don't do it. It's much better to let the crud flow than to block up the system. If you think there's that much crud in your system, flush it and put in the right amount of antifreeze so the block doesn't rust.
Old Jun 19, 2003 | 08:31 PM
Ecuri's Avatar
Ecuri
Steve is right on. The one thing I will add is use a quality anti-freeze... the cheaper ones do not have the same anti-corrosion additives as the better brands, ie Prestone.
Old Jun 19, 2003 | 10:53 PM
jrs_big_ford_f150
I use Prestone, and good clean water. I just happened to find some steel mesh laying around and remembered a post from way back explaining how to make one. I thought it was a good idea. Oh well. Thanks anyway guys.
Old Jun 24, 2003 | 04:44 PM
GammaDriver's Avatar
GammaDriver
I agree that any system that could potentially block your main coolant flow hoses is highly problematic. Thus:
https://www.ford-trucks.com/forums/s...%2Bgammadriver
Best,
Old Jun 25, 2003 | 12:15 AM
jrs_big_ford_f150
Hey GammaDriver, where can I find that canister filter setup? I would like to pumb one in to my system.
Old Jun 27, 2003 | 06:11 PM
rebocardo's Avatar
rebocardo
You can find cannister type filters for coolant at any heavy duty truck (tractor) or fleetshop. Just go to the yellow pages and find a store/shop for HD truck parts. You might find them at www.ryder.com
The reason for having these things is because on large diesels impurities can cause uneven cooling or vapor pockets on the cyl. walls which overtime can destroy an engine earlier than normal. People try to get 500K-1000k out of an engine, plus these engines have fairly large cooling surfaces.
I do not think you will get a ROI using your I-6. I think it would be much better to do oil filters and changes every 3k and change all fluids (including brakes) every two years or 30k.
Old Jun 27, 2003 | 06:16 PM
jrs_big_ford_f150
Question for Rebocardo, what is ROI ?
Old Jun 27, 2003 | 06:20 PM
Bikeitswift's Avatar
Bikeitswift
ROI = Return on Investment, also Dale's Husband's name with one of those California spellings. as in.."Pardon me Roi, is that the cat who chewed your new shoes??" What ever happened to Roi Clark?
Old Jun 27, 2003 | 06:26 PM
GammaDriver
I agree with rebocardo. I think the hose-ends and screened-washer are your best investment, as they are cheap.
But NAPA may have the system you are looking for. I do know they carry coolant canister filters for units that have them.
Spend the money on a canister power steering fluid filtration system if you are serious about filtering fluids, but I wouldn't go too far overboard with filtering the coolant unless you can think of a problem you know of that it would solve (machining debris?).
Best,
Old Jun 28, 2003 | 11:18 AM
jrs_big_ford_f150
Thanks guys, I have decided that it is not effective for a filter setup. I am just going to keep the fluids changed on a regular basis. Thanks again guys.
Old Jun 28, 2003 | 11:35 AM
GammaDriver
Oh, it's effective - I catch junk all the time on my screen. It's just probably not worth the cost of buying the canister system you desired.
Old Jun 28, 2003 | 08:52 PM
jrs_big_ford_f150
GammaDriver, this screen type filter you speak of, how does it work? I have some metal screen mesh in good shape. Does it go in one of the coolant hoses or something? I would like to know more about this one.
Old Jun 28, 2003 | 09:15 PM
GammaDriver
It's all there in the posts. Read the links provided (above, and in that thread) and you'll get the idea.
Old Jun 28, 2003 | 11:29 PM
jrs_big_ford_f150
Thanks GammaDriver. I found what I was looking for. Your link was most helpful. I was suprised to see that the old forum system is still around (DC forum I believe it is) Anyway, Thanks a bunch.
idiabuse
Aug 17, 2014 11:31 AM
vectrex
Apr 23, 2012 02:56 PM
usmc161
Jul 14, 2010 09:31 PM
ssian
Oct 21, 2009 12:04 PM
dagren99
Dec 28, 2004 08:18 PM
