normal perdel#s ?
Old Sep 30, 2013 | 01:42 PM
Mr. Finch's Avatar
Mr. Finch
normal perdel#s ?
i have a 2001 f350 6spd, did some work earlier this year, injector cups, o-rings, timing cover.
i was just curious what would be considered "normal" for this truck with 245,000 and no fuel mods/upgrades, and the "revised" cps (rougher idle but longer life)
i know due to the "dead head" issue, #3 and #8 read high, but about high high is normal, and any other cylinders read more than 0?
thanks.
Old Sep 30, 2013 | 07:59 PM
joeyd61's Avatar
joeyd61
IMO, with the exception of the dead head issue some will say between 0 and 3 is ok. Personally on mine its between 0 and 2 on all 8, but I don't have the dead head problem
Old Sep 30, 2013 | 08:06 PM
F350-6's Avatar
F350-6
Pm me in a few weeks. Once I get my laptop fixed, I'll find some old perdel readings from my truck back when I only had 250k on the clock.
Old Sep 30, 2013 | 09:40 PM
Tugly's Avatar
Tugly
I was anywhere from 0 to 3 with a good CPS, then my new sticks are all less than 1. I have one injector with a 3 sometimes, and I can feel the difference. I once had a bad stick that went up to about 7, and that ran like crap.
Old Oct 1, 2013 | 01:10 PM
Mr. Finch's Avatar
Mr. Finch
thanks, i am going to get the latest reading tonight on my way home (if i remember to bring my scanner). i am looking at doing riffraff's fuel and oil crossovers soon and compare before/after. i just seam to have a rough idle compared to other trucks in the area, but most of the 7.3's are gone, and the ones left are all auto with higher idles, so it is hard to compare based on sound alone.
Old Oct 1, 2013 | 01:37 PM
Mr. Finch's Avatar
Mr. Finch
ok, just took lunch, and after it warmed up my reading are
#1 0.2 to 0.4
#3 consistant 2.6
#5 0.6 to 0.8
#8 2.9 to 3.4
from the sounds of it these #s are about average right? should i be a little concerned about #s 3 & 5? when i did the cups all cylinders had compression of around 450psi except for the front 2 on pass side where 400-425.
Old Oct 1, 2013 | 01:52 PM
Mr. Finch's Avatar
Mr. Finch
almost forgot, it is a cali truck, has gp module instead of relay etc.
Old Oct 1, 2013 | 02:22 PM
Tugly's Avatar
Tugly
Those are all normal... roll with it.
Diesels don't idle glass-smooth unless you go through the process of having the injectors pressure/flow tested for a smooth idle. I had that done when I replaced my injectors, so I expect a bit more on Stinky, the wondertruck.
Old Oct 1, 2013 | 02:32 PM
Mr. Finch's Avatar
Mr. Finch
thanks, i know these things are always a bit rough, but with everyone around driving newer trucks that SOUND smooth, and with the lower compression on #1 and 3 i was curious. i have atleast one broken/fallen oil jet and i am starting a small business so i have to keep pushing off the repairs so then the paranoia kicks in lol.
bubba_3711
37
May 9, 2012 03:34 AM
brian44
25
Oct 2, 2011 08:42 PM
Scratch
13
Jul 28, 2007 01:17 AM
AngeliasDad
Jun 8, 2007 11:54 PM
elkarcher
Mar 26, 2006 10:48 AM
