2002 7.3 injector issues?
Old Sep 30, 2011 | 02:51 PM
brian44's Avatar
brian44
I just replaced all 8 injectors and gaskets(didn't replace the old connections but told to only if there was a meltdown of old ones) in my 2002 f350 7.3.Idles a little rough,computer shows #S 3,5 & 8 as being bad.Replaced those 3 with new ones and computer shows the same codes?Check engine light comes on periodically,it's like a slight miss when you hit the accelerator but then runs great.What else could be the problem.Ran a compression test and it checked out and fuel pressure is 69+.My mechanic buddy is good it's just that he doesn't work on diesels much.Any help would be greatly appreciated.Brian in Central Texas.
Old Sep 30, 2011 | 03:22 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE, Brian.
Do you have the gray CPS installed? The gray CPS always shows my #3 and #8 bad, but they are working fine. How many miles have you driven the truck since you changed the injectors?
Old Sep 30, 2011 | 03:27 PM
brian44's Avatar
brian44
2002 f-350 injector issues
Excuse my ignorance,what is grey cps.I've driven about 75 miles and was told to drive it hard cause maybe air in the system.Thanks
Old Sep 30, 2011 | 04:08 PM
miller_feed
Have you had the dealer change the CPS for the recall? Look at this link for CPS info. Welcome to guzzle's CPS R&R Web Page<
Old Sep 30, 2011 | 04:33 PM
brian44's Avatar
brian44
Yes I had that replaced quite some time ago.You switched yours back to the black one?
Old Sep 30, 2011 | 04:47 PM
miller_feed
Not yet. I still have the gray one in and the black one I got from Clay in the glove box. Truck runs good, just shows the 3 and 8 injector bad.
Old Sep 30, 2011 | 04:55 PM
brian44's Avatar
brian44
Does yours idle a little rough and the check engine light come on periodically?Does it have a slight hesitation when hitting the accelerator?
Old Sep 30, 2011 | 05:51 PM
Shake-N-Bake's Avatar
Shake-N-Bake
What codes are you getting?
For future reference, computers can NOT determine if injectors are bad. An injector code could be anything from broken wire, loose/bad connection, solenoid, CPS etc. What are you using to interface with the PCM to run diagnostics?
Write down and then clear your codes. Start your engine, drive around for a little bit and check codes again. Post the results back here and we can help you with the next step(s).
Old Oct 1, 2011 | 08:33 AM
miller_feed
No, no problems with mine. You should put more miles on it to make sure it's not air.
Old Oct 1, 2011 | 10:29 AM
brian44's Avatar
brian44
I will and thanks for the help Rick.
Old Oct 1, 2011 | 10:36 AM
brian44's Avatar
brian44
Ok thanks.
Old Oct 1, 2011 | 01:35 PM
mikeyc0120's Avatar
mikeyc0120
Just a question... have you done the 50 cent mod? The valve cover plugs might be an issue...
Old Oct 1, 2011 | 04:15 PM
brian44's Avatar
brian44
Thanks I'll have to check that out.It only acts up when it's in drive and sitting still.Once you accelerate or its in park or neutral it runs fine.
Old Oct 1, 2011 | 10:34 PM
driximus's Avatar
driximus
Sounds like what my truck was doing, Couldn't figure it out.
Old Oct 2, 2011 | 12:10 PM
brian44's Avatar
brian44
So it still does it?
