Please recommend alternator size
Old Sep 30, 2013 | 01:48 PM
  #46
MoyockPowerstroke's Avatar
MoyockPowerstroke
Okay, so I've been thinking about the Ford OEM 140a upper/duel alt setup alternator. This alternator along with the 3g 58mm overdrive pulley should be all I need. With a 10% military discount both can be had for $180 + tax (approx $11 bucks).
Knowing that the 140a is used in the stock configuration for dual alt setups...what difference is there in the OEM wiring? Does Ford use heavier AWG wiring for the dual alt applications? If not, then as long as I upgrade to the above setup, I should be fine without modifying the wiring ...is that correct? If they use heavier AWG wiring, I should be able to purchase that from Ford or International.
Anyone know if there is a difference between the two wiring setups?
Old Sep 30, 2013 | 02:41 PM
  #47
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You do not have to upgrade or change anything installing the 140 amp 6G.
Once you go beyond 200 amps it would be a good idea to upgrade or piggyback the charge cable.
Josh
Old Sep 30, 2013 | 02:44 PM
  #48
MoyockPowerstroke
Josh
Thanks Josh....sounds like the plan then.
Ray Hamel13
Dec 4, 2013 03:38 PM
davbeisner
Mar 22, 2013 01:25 PM
brandon.edwards
Feb 2, 2013 07:46 AM
freef2504x4
Jan 23, 2011 11:58 AM
JIMY
Electrical Systems/Wiring
Aug 11, 2004 02:08 PM
