Please recommend alternator size
Old Sep 28, 2013 | 03:13 PM
Saxon's Avatar
Saxon
My truck is a '06 F250 King ranch 6.0 and I have no output from the alternator. Even with the truck running VDC is just 12.7.
Which alternator size is best? Amperage?
The local Advance Auto has a rebuilt 110 amp for $180
My system is single alternator.
Thanks
Old Sep 28, 2013 | 03:15 PM
Will Bite's Avatar
Will Bite
https://www.dcpowerinc.com/fit/2006~...7-185-oem.html
Old Sep 28, 2013 | 03:28 PM
BLADE35's Avatar
BLADE35
DC POWER ALTS Are some the best out there
I would go with something that puts out at least 140AMPS@Idle
A 110AMP ONLY KIcks out 80-85AMP@ Idle so its way under powered
Old Sep 28, 2013 | 03:35 PM
the_auto_tech's Avatar
the_auto_tech
If you want a nice, cheap, easy to find upgrade simply pick up a 140 amp upper alternator from the dual alt system for the 6.0. I picked up a lifetime replacement one from O'Reilly's for approximately 150 bucks and they keep them in stock. Direct replacement. I also installed an overdrive pulley I got from eBay onto it and couldn't be happier.
Old Sep 28, 2013 | 03:39 PM
Yahiko's Avatar
Yahiko
I did the same ^^^
And I am happy with it.
DC POWER would be a better pick but the backorder status was so
bad that I passed on it.
Sean
Old Sep 28, 2013 | 03:44 PM
Saxon's Avatar
Saxon
Ya'll have informed me well, thanks a lot.
Is a overdrive pulley a smaller diameter? Therefore it spins faster?
Old Sep 28, 2013 | 03:47 PM
the_auto_tech
Originally Posted by Yahiko
I did the same ^^^
Sean
I will agree that a DC Power alternator will put out more power, but it also costs 3 times as much and are on backorder for a ridiculous amount of time. I don't feel I should have to buy a DC Power alternator and carry a stock one if it fails because I can't easily get another DC Power easily. If that's the case I'll just run the 140 amp large case 6G and once it dies simply walk into the store and get another one for free.
Old Sep 28, 2013 | 03:49 PM
the_auto_tech
You got it exactly right. The overdrive pulley is a 58mm, with the stock pulley being a 72 or something along those lines. With the stock 110 alternator and pulley I was getting down into the high 10 volt area during glow plug cycle on startup. With the 140 and overdrive I'm usually sitting around 12.5 and once the glow plugs go off it jumps to 14.2 quickly whereas the stock setup would have to climb back up to the high 13's.
Old Sep 28, 2013 | 03:53 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Keeps the same belt?
Old Sep 28, 2013 | 04:01 PM
the_auto_tech
Yep, just make sure you get the right one. I don't have the specs exactly but if you look up 6G alternator pulley on eBay it should pop up at the top of the list. It's like 18 bucks. I think it's a 6 groove. The belt tensioner takes up the slack without a problem.
Old Sep 28, 2013 | 04:19 PM
Saxon's Avatar
Saxon
Dog gone good info.
Old Sep 28, 2013 | 04:24 PM
Saxon's Avatar
Saxon
I am so glad to have my 89 F150 as my other truck. It is worth more to me than what I could sell it for. I have had it since 1990. Yee Haw
Old Sep 28, 2013 | 04:51 PM
smokersteve's Avatar
smokersteve
I agree. this is a great alternator. much better than stock. But only a 2 year warranty...
Get an alternator with a life time warranty. For me, Warranty plays 70% of my purchase decision
Autozone has a lifetime. I got mine from them.
Old Sep 28, 2013 | 04:55 PM
smokersteve
Gold Duralast/Alternator (DLG3668-8-11) | 2006 Ford F350 Super Duty P/U 4WD 8 Cylinders P 6.0L Turbo Diesel | AutoZone.com_
140amp. upper alt.
Old Sep 28, 2013 | 05:55 PM
BLADE35's Avatar
BLADE35
But that's OK for Folks like us that are Gearheads with a Truck Cab that looks Similair to an F-16 Fighter Cockpit with ALL the Gauges
But for someone that don't have Gauges or say maybe there Wife ride that Oreillys alt may die and Take the FICm with it IF its not caught in time so if this were to Happen was the couple hundred Bucks saved on a Cheap Alt really Worth it??
