Please recommend alternator size
Old Sep 28, 2013 | 06:56 PM
the_auto_tech's Avatar
the_auto_tech
Originally Posted by BLADE35
But that's OK for Folks like us that are Gearheads with a Truck Cab that looks Similair to an F-16 Fighter Cockpit with ALL the Gauges
But for someone that don't have Gauges or say maybe there Wife ride that Oreillys alt may die and Take the FICm with it IF its not caught in time so if this were to Happen was the couple hundred Bucks saved on a Cheap Alt really Worth it??
I don't let anyone drive my truck that can't watch the gauges in it, so that's a non-issue. Also, if the alternator dies you have the battery light as a backup at least to warn if you you're not watching the gauges. The DC Power alternator has the same scenario anyways, but it's worse because you can't quickly replace it.
Old Sep 28, 2013 | 06:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Good, fast and cheap would be a large case 130 amp 3G or large case 140 amp 6G. Both with the 58mm pulley.
Otherwise there are DC Power, Mechman, and Singer high output alternators.
Josh
Old Sep 28, 2013 | 07:23 PM
olfordsnstone's Avatar
olfordsnstone
I had thought there was a difference with the DC Power Alternator, where it continued to charge through the glow plug cycle, or something like that. Was I dreaming or was there something I read on that a while back?
Old Sep 28, 2013 | 07:41 PM
69cj's Avatar
69cj
No alt. is bullet proof. That could happen with a DC alt. also. My point is that on the road your not going to get the DC alt. in time to do you any good and a lifetime warranty is gravy in the pot. Your choice but I'll take the coast to coast warranty. Let me know when DC gets your replacement back to the east coast.
Old Sep 28, 2013 | 09:29 PM
BLADE35's Avatar
BLADE35
Right Unlimited warrenty is Great Its about Impossible to Beat it "Its FREE Wrench Day for GearHeads LOL"
When my DC Power Dies it will have to go to a Rebuilder Local I know what you mean about DC
Im shure at some point I will end up with a Cheapy to get by
It don't have to be DC Power I would Stress Power output would be the Main concern OVER the Brand
I'm curious to see how long some these cheaper alts last that has a Smaller pulley put on if they Last long getting Spun Harder
Old Sep 28, 2013 | 10:52 PM
Yahiko's Avatar
Yahiko
And if you are into repairing things the
bearing replacement it not that hard/
It's the regulator assembly that will get you.
It houses the brushes also.
So a new regulator comes with new brushes.
Sean
Old Sep 28, 2013 | 11:52 PM
Hank85713's Avatar
Hank85713
DC has the alts in stock ordered one last week $229 delivered. Installed it last night 500 mile trip today worked well.
Old Sep 28, 2013 | 11:54 PM
Bullitt390's Avatar
Bullitt390
We are talking diesels here, not high revving 7000+ rpm V6's or V8's LOL
The 93-97 7.3 3G came stock with the small pulley.
Josh
Old Sep 28, 2013 | 11:56 PM
Bullitt390's Avatar
Bullitt390
The cheapest DC Power alternator is the 185 amp at $298 + shipping
Josh
Old Sep 29, 2013 | 12:08 AM
BLADE35's Avatar
BLADE35
Ya the extra RPM cant be Much from the Smaller Pulley can it Josh
I just thought it may run Hotter is all and really probably a Moot Point
Old Sep 29, 2013 | 12:14 AM
Yahiko's Avatar
Yahiko
The more AMPs it making will heat it up.
The RPM only comes into play with the bearings
ans the rotating assembly aka The Rotor.
Sean
Old Sep 29, 2013 | 12:24 AM
BLADE35's Avatar
BLADE35
Sean
Right but now it Has More RPM it can Produce More Amp when say before the Pulley was installed it may have been Doing all it could Per the RPM at the Time
I don't think it enough to worrey about though for Stock setup
Old Sep 29, 2013 | 01:01 AM
  #28
Hank85713's Avatar
Hank85713
Josh sorry but DB electrical is the one I got.
Old Sep 29, 2013 | 06:59 AM
  #29
jdw1's Avatar
jdw1
Here is another option 6G Series High Output Alternator with Extra Heavy Duty Components
I am running one of these on my 02 with a snow plow for 3 years now with good results, one thing to consider would be to up grade and have your current alternator rebuilt and carry as a spare when you travel.
Just another option
Old Sep 29, 2013 | 09:13 AM
  #30
Saxon's Avatar
Saxon
I found a 140 A upper at Advance for $135 , reman. stock pulley
How imprtant is the smaller pulley?
