Something brand new...
Sep 25, 2013 | 11:06 PM
Yes, i understand. But the drive shaft still rotates? Cuz im sure mine does. Cuz the zerk is always in a diff spot.
Sep 25, 2013 | 11:10 PM
Crawl under and spin it with the truck off. It should be free
Lol, refreshed, now lost. So the front drive shaft can still turn?!
Sep 25, 2013 | 11:13 PM
Doesnt turn, both hubs are free
Sep 25, 2013 | 11:14 PM
In 2 hi, the transfer case is not hooked to the front shaft. But if something in your frontend is broke, it may still be spinning. And broken parts can cause noise.
Sep 25, 2013 | 11:18 PM
Pull the hubs, the dark part. One Phillips screw. Spring behind them too. Duct tape up the hub to keep dirt out and drive it to work for a day. Betting your noise goes away
I just shifted to neutral, it rolled, then down to HLand up to Hi2, driveshaft moves 5/8"
Sep 25, 2013 | 11:20 PM
Ok, i will do that. Maybe the broken hub is keeping it engaged?
Sep 25, 2013 | 11:22 PM
I cant get a correct spline set of hubs off cl for $65
Sep 25, 2013 | 11:23 PM
Sep 25, 2013 | 11:24 PM
I would get em from Napa or such, warranty is cake. Bout the same price, in the mudwest any way.
*edit. Diagnostic first
I left it in as a spacer, i thought it was disengaged
Sep 25, 2013 | 11:25 PM
They are $70-$80 each here
