Something brand new...
Old Sep 25, 2013 | 12:22 AM
  #31
xkpsanit's Avatar
xkpsanit
Originally Posted by Jklnhyd
Anyone know why?😒
How many pumps did you put in there? It will squirt out of a vent hole on the end inside the yoke.
Old Sep 25, 2013 | 12:35 AM
  #32
Jklnhyd's Avatar
Jklnhyd
20 or so, til the gun was empty. It didnt come out the spline side, it came out the other side by the u joint. Is there a seal or something in there? Sorry, im not sure about what i am doing
Old Sep 25, 2013 | 09:07 AM
  #33
Jklnhyd's Avatar
Jklnhyd
Constant vibration during accereration started this morning. Could be ujoints? Unbalanced driveshaft? The front driveshaft has a lot of play😓 fml
Old Sep 25, 2013 | 09:10 AM
  #34
Jklnhyd's Avatar
Jklnhyd
Like 5/8" inch play....
Old Sep 25, 2013 | 09:18 AM
  #35
xkpsanit's Avatar
xkpsanit
Yeah too much. 4 to 6 is more like it. Your shaft compressed and pushed it out like a syringe. Your mess is normal. No seal, the weep hole needs to be there to "protect" the spline seal. It vents compression and vacuum from the shaft telescoping.
Old Sep 25, 2013 | 10:17 AM
  #36
Jklnhyd's Avatar
Jklnhyd
Ahhh, kk, makes sense
Old Sep 25, 2013 | 10:50 AM
  #37
Sooper Camper's Avatar
Sooper Camper
what do you mean by 5/8" of play. almost sounds like the slip yoke is hosed. this is the rear shaft we are talking about correct?
Old Sep 25, 2013 | 11:07 AM
  #38
Jklnhyd's Avatar
Jklnhyd
The front shaft... I can turn it 5/8" back and forth. I have never had a 4x4 so lots of this is new to me
Old Sep 25, 2013 | 11:08 AM
  #39
Jklnhyd's Avatar
Jklnhyd
The rear drive shaft has no play
Old Sep 25, 2013 | 03:38 PM
  #40
xkpsanit's Avatar
xkpsanit
Ok... the 5/8 front shaft comment makes me wonder; are you driving around in 4×4??
Old Sep 25, 2013 | 03:47 PM
  #41
Jklnhyd's Avatar
Jklnhyd
No, never in 4wd, my front left hub needs to be replaced. So i have never tried.
Old Sep 25, 2013 | 03:52 PM
  #42
Jklnhyd's Avatar
Jklnhyd
But the POS that had it before me did, if i remember right.
Old Sep 25, 2013 | 04:20 PM
  #43
Jklnhyd's Avatar
Jklnhyd
Back story: i bought the truck 2 months ago, from a guy that had it for 5 months, and he bought it from a friend of his mother-in-law or something, that moved to Vegas. And i think it had been sitting for a number of years. The tires that were on it literally started falling apart from dry rot, and many of the seals are failing. I have been doing something to it every weekend for 2 months.
I dont have a lot of tools, or a place really to work on it. So slow and go, money is tight😁
Old Sep 25, 2013 | 05:49 PM
  #44
Jklnhyd's Avatar
Jklnhyd
Was also thinking, it always happens after i drive home from work, after i pick my daughter up. Imma check the tranny fluid again, hopefully it is too high
Old Sep 25, 2013 | 06:21 PM
  #45
Jklnhyd's Avatar
Jklnhyd
Its too high...quite a bit. I checked it before after idling 20 minutes, not driving...
