#8 injector change
Old Sep 19, 2013 | 08:49 PM
powerfloat's Avatar
powerfloat
#8 injector change
You all have me scared about autolite glow-plugs from a previous threads so I will be pulling my driver side valve cover to see what type the previous owner put in. While I'm in there, I have been considering changing the #8 injector from the AE LL to a plain old AD injector now that I have a regulated fuel return mod installed. Does anyone have any experience with this? good idea or bad idea?
Old Sep 19, 2013 | 11:52 PM
Traildust's Avatar
Traildust
I replaced my #8 AE for a regular AD Injector. It was three or four years ago but I can say it was a fairly straight foward job, just make sure you get all the oil/fuel out of the cylinder before you turn it over the first time. I have not had any trouble with it since. It did reduce the knocking sound by about 25% at most.
Old Sep 19, 2013 | 11:55 PM
jgilrfr's Avatar
jgilrfr
#8 isnt too bad to do i just did all 8,dont loosen the top bolt, remove the oil deflector and the bottom bolt slide the plate up and pry under it leveraging from the top and it will pop out
Old Sep 19, 2013 | 11:56 PM
jgilrfr's Avatar
jgilrfr
also torque all the top bolts to the same amount 12 ft lbs while you are at it
Old Sep 20, 2013 | 06:38 AM
Tugly's Avatar
Tugly
I had a ft/lb torque wrench when I did mine and my injector hold-down bolt problems were epic... really. Acquire an in/lb torque wrench, even if it's rented or borrowed. THe spec calls for 120 in/lbs, many recommend 130 in/lbs, and I read a magazine article where they urge 140 in/lbs. With such varying opinions and my experience with this, that 120 in/lbs seems to be inadequate. I ultimately landed on 130 in/lbs, with an extra 1/8th-turn for good measure.
Drain your fuel bowl before you pull the stick, it sends less fuel into your oil.
Don't install anything until you've consulted with us on how to clear all the fluid out of the cylinder.
Old Sep 21, 2013 | 12:34 AM
Bonanza35's Avatar
Bonanza35
Any reason you want to change the #8 Injector? Dose it knock bad or you just want to do it. I did change mine but it still had a fuel knock with FRX. Fuel tank mods should be done also.
79Supercab
31
Mar 12, 2014 07:26 AM
florida_1959
Apr 3, 2012 08:57 PM
bigbubba87
Aug 16, 2011 09:31 PM
PhilnMarilyn
Aug 18, 2010 07:14 PM
holiday187
Dec 7, 2007 09:51 AM
