Yes, shocking, I know. I have a 1993 Taurus GL 3.0 with the 4-speed auto and I am having transmission problems.
Trans worked fine when I drove into parking lot. Came back 30 minutes later, and trans is dead. When I shift into any gear, the engine loads and the car lurches a little. However, when I press the accelerator, the engine revs but the car makes absolutely NO attempt to move. This happens in every shifter position. Trans fluid level is correct.
The car has 140,000 miles on it and is not worth $1500 for a rebuilt trans. However, I am willing to gamble $200 on a rebuild kit. I am thinking about dropping the pan, pulling the valve body, and rebuilding it with new seals from the kit, and pulling all of the pistons to clean and replace seals. Then put it back together and try it out.
Expert opinions wanted: am I wasting my time and money? Should I just shoot it and haul it to the scrap yard?
I don't understand what you are planning to do. Are you planning on removing the trans and rebuilding it, or just removing the side pan (NOT the bottom pan) and rebuilding the valve body?
My plan is to pull whatever pan(s) I need to pull to get to the valve body and pistons. Clean and rebuild the valve body and clean and put new seals on the pistons.
I could get a trans from a junk yard, but that is more money and work than the car is worth and I would still have a trans that might not even work.
Bottom line: I am choosing between attempting a relatively easy job and hoping that it works, or taking the car to the scrap yard and walking away with $300 in my pocket. The car is in pretty good shape, all things considered. It was garage kept all of its life. However, it has NO options. It has a market value of about $500. If I can fix the trans (i.e. make it work for another few years of light driving) for $200, great. If not, I'll take the $300 for scrap value.
you really need to open up some pressure taps and take some readings
Hmmm... It sounds to me like the best thing would be to tow it to a shop where they know this trans and have them diagnose it, then decide what to do. If it's just one bad solenoid, it could be reasonable to fix it. I'd have to buy a shop manual and pressure gauges just to get started.
Or .... upon further consideration ... if a solenoid has burned out, I should be able to find that pretty easily with an ohm meter. I will check the solenoids and see if one is open or shorted.
There are no pistons that are accessible through either pan. If you want to replace the clutch piston seals the trans has to come out and get completely torn down. That's a rebuild. It cannot be done with the trans in the car.
I think the idea of a failed control solenoid makes the most sense. The trans has worked perfectly until it stopped working altogether. There was no gradual decline, or funky behavior. I'll bet a control solenoid failed. Hopefully it will be easy to find and fix.
