Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
I need a source or sources for 63 F-600 brake parts
Old Aug 31, 2013 | 08:58 PM
Ams1069's Avatar
Ams1069
I lost the brakes in my 63 F-600 today. It's time to go through the entire system. I am looking for wheel cylinders (or rebuild kits), shoes, rubber lines. The master cylinder and hydro vac seem fine.
I searched the forums but the information was at least 3 years old. Anyone have a source for these parts?
Old Aug 31, 2013 | 09:48 PM
85e150's Avatar
85e150
Some say NAPA will have those, but you need to know exactly what you have going in. It is possible several brake sizes were used on your truck.
If you post your VIN (just for grins) and the info off the data/warranty plate on the door, you may get a decode for the axle and other info. '63 though should be before the multiple types of brakes like the later Girling systems that you are glad you don't have for example.
Old Aug 31, 2013 | 10:03 PM
awhtx's Avatar
awhtx
Here is a link to a shop in Minneapolis that can help you with just about anything you may need.
Machine Shop
Old Sep 1, 2013 | 07:24 PM
Ams1069's Avatar
Ams1069
Thank you for your help. The vin is f60BK372436. Axle code is f2. Which I think is an eaton 2 speed.
I replaced the faulty wheel cylinder with one from an f-350. It appeared to be exactly the same as the one I removed. The front brake shoes are 14x2.5. I haven't removed the rear drums yet.
Old Sep 1, 2013 | 09:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ams1069
I lost the brakes in my 63F600 today. It's time to go through the entire system. I am looking for wheel cylinders (or rebuild kits), shoes, rubber lines. The master cylinder and hydro vac seem fine.
Before you buy a single part, you will need to know what size the brake shoes are.
Front could be: 14" x 2.50" or 16" x 2.50."
Rear could be: 15" x 4.00" or 15" x 4.50" or 15" x 5.00" or 16.50" x 4.50."
Old Dec 11, 2013 | 04:49 PM
56ford750's Avatar
56ford750
63 f600 brake parts
Hi, did you find your brake parts yet? I just finished collecting all NEW parts for my truck if you need any numbers. Your rear is likely the same as mine.
Old Dec 14, 2013 | 06:09 PM
Ams1069's Avatar
Ams1069
Numbers would be great. I have been working on other projects and haven't done much with my truck. When spring hits I need to be ready to go through the brakes and replace the wheels.
thanks
Old Dec 14, 2013 | 07:40 PM
56ford750's Avatar
56ford750
After some time spent at NAPA looking at wheel cylinders from several models and years, this is what we came up with for mine. These were for a 1960 two speed rear and are a 1 5/8 bore. I am sure that they fit other years as well. Most wheel cylinders are available, you just need to know how to find them. All four rear wheel cylinders are different two each share the same casting number but are drilled out for a different position on the axle. The cylinder on each box may not match the number, they are the old ones and are mixed up, but the four shown make up the group.
My front would not do you any good because they are correct for my '56. I was able to find brand new cylinders for my front as well as a new master cylinder. All new production!
Old Jun 2, 2015 | 11:58 PM
Kevin1966f600's Avatar
Kevin1966f600
Napa and fleetpride
Bob Doss
Large Truck
Jan 24, 2023 05:36 PM
Ryan Ward
Jul 11, 2019 11:45 PM
Glenn54
17
Dec 7, 2016 07:50 PM
mpoulton
Sep 15, 2007 10:42 AM
dschr
Jan 13, 2005 10:56 AM
