Blinking overdrive light
Old Aug 30, 2013 | 08:37 PM
DND58's Avatar
DND58
Have friend on road in 2001 auto trams. Just crested steep hill and overdrive light blinking. Stopped at top and idled in park and light went out. No gauges on board. Will high temp set a blinking overdrive light?
Old Aug 30, 2013 | 09:33 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
It means a code is stored, dunno if simple high temp will do it. If the fluid looks/smells good and no other symptoms I'd keep on trucking and pull the codes when convenient. When hot the front seal can leak some fluid, then when cool it can re-seal well enough to get down the road to the next over heating event. Top it off if needed.
Old Aug 30, 2013 | 09:39 PM
mueckster's Avatar
mueckster
P1783.... Trans Fluid temp has exceeded 270*F....Slight increase in EPC pressure. May flash Overdrive light.
Old Sep 2, 2013 | 07:10 PM
comadvan's Avatar
comadvan
Almost always overheated fluid.. I got it once after installing my 6.0l cooler running empty and found that the TCS connector wires were all green and falling out of plug.
Old Sep 2, 2013 | 08:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes it will, but so will at least 50 other things, too. The ONLY way to know why it flashed is to get the codes read. The code will stay in memory for about a month after the last time the light flashed. Auto parts stores CANNOT read these codes.
23zuklin
Feb 27, 2016 03:36 PM
rkp
18
Sep 3, 2010 11:55 AM
plowguy
Jan 6, 2006 06:23 AM
Mogy
Mar 4, 2005 01:32 PM
live2hunt
Electrical Systems/Wiring
Apr 26, 2004 04:54 PM
